Fix Your Stuff
Right to Repair
Store
Help
Editing Step 2 —
Notice: You are editing a prerequisite guide. Any changes you make will affect all 2 guides that include this step.
Step Type:
Drag to rearrange
Keep your hand pressed firmly on the back panel to prevent it from falling.
Flip the laptop over horizontally and open up the lid.
Insert the tip of the plastic opening tool into the upper left corner of the panel.
Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
Remove the four 2mm Phillips #0 screws at the top of the keyboard.
Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
