Help
Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown
Editing Step 13 —
Step Type:
Drag to rearrange
The 55mm fan can be removed from the underside of the heat sink.
Flip the heatsink over so that the thermal pads are facing you.
Remove the two thermal pads covering the fan screws.
Use a Torx T10 bit to remove the fan screws.
