Help
Netgear Nighthawk AX8 8-Stream AX6000 WiFi Router Teardown
Editing Step 6 —
Step Type:
Drag to rearrange
Each antenna is plugged into the mainboard with a simple snap connector.
Lift off each snap connector with your fingers or a plastic spudger. It is recommended you label these in order from top to bottom so assembly is easy.
The antenna wires are also run through 'teeth' on the board. Pull the wires out of each tooth.
