Help
Dell Latitude 7420 Keyboard Replacement/Teardown
Editing Step 14 —
Step Type:
Drag to rearrange
start on the right side at the USB C daughter board.
lift up the motherboard where the fan used to be
you should be able disconnect the daughterboard and mother board
the USB C port on the left might be tight. Use your fingers to slightly bend the laptop casing outward to the left above the usb c port
lift out the motherboard vertically
lift out USB C daughter board vertically. use the frame bending trick if necessary
