Fix Your Stuff
Right to Repair
Store
Help
Editing Step 15 —
Step Type:
Drag to rearrange
Ouya Repairability Score: 9 out of 10 (10 is easiest to repair)
The batteries are standard AA. Plus, they're easy to access and replace without tools.
Only standard-head screws are used (Phillips and Hex).
Many components are modular and simple to remove, making them easy and cost-effective to replace.
The heat sink is soldered in place, so if you need to replace the thermal pad, or repeated fan-swapping strips the threads, you'll need some soldering skills.
The joysticks are soldered to the circuit board, so if your button-mashing gets out of hand, you may need to replace the whole board.
