Fix Your Stuff
Right to Repair
Store
Help
Editing Step 10 —
Step Type:
Drag to rearrange
We head south, and with the bottom cover removed, we find a jungle of cables and rubber gaskets.
Rule #19 in the scout’s handbook: Never forget the SIM card tray. Rule #21: Use as many tools simultaneously as you can.
All those components are individually replaceable: From the USB-C port through the interconnect cables, over to the vibration motor, finger print sensor, and its breakout cable.
On the daughterboard, we spot one connector that has no rubber gasket around it—the display connector. But don’t panic—the cable from the display carries the gasket.
