Help
Editing Step 4 —
Step Type:
Drag to rearrange
If the camera happens to have a problem (like the one shown) where the shutter does not open or close fully, this can be fixed at this point.
Often, simply disassembling and reassembling the shutter assembly will be enough to get it working again. If not, a quick rinse in distilled water can remove any residue or debris which might be jamming it.
The shutter is opened and closed by the tab indicated in the green circle. When the camera is assembled, this tab is pushed as the lens extends and retracts.
If you disassembled the lens, put it back together by reversing these steps, then pop the battery back in so it will retract before proceeding with disassembly of the main camera. Remember to take the battery back out before continuing.
