Help
Editing Step 16 —
Step Type:
Drag to rearrange
Now there will be a tiny circuit switch upright after removing the fan channel.
Remove simply by lifting out out placement niche
This, I found is a neat little cutoff switch. Being that the little black switch is located at the underside of the unit in the Lamp assembly door. If the Switch is not depressed that means the door is not closed and power will not be applied to the lamp-Safety Feature
