Help
Editing Step 17 —
Notice: You are editing a prerequisite guide. Any changes you make will affect the guide that includes this step.
Step Type:
Drag to rearrange
Removing the Fans.
Remove the 3-Pin power connector from the logic board. This is the same connector used in some PC fans.
Using a flathead screwdriver, pry the fans toward you.
Pull the fans toward you, then lift them out of the casing.
