Fix Your Stuff
Right to Repair
Parts & Tools
Help
Editing Step 1 —
Step Type:
Drag to rearrange
To make a coloured image, the light shines through this spinning colour wheel then onto a Digital Micromirror Device (DMD) with 1024*768 small mirrors that move to switch each pixel on or off.
Remove these 2 silver 6mm Philips #1 screws to detach the colour wheel.
To remove the colour wheel you will need to cut a cable tie and move the wires to the side.
Then gently remove the delicate glass colour wheel.
Interesting Fact: the light at this point is in a narrow beam that passes through a hole 4mm * 5.3mm.
