Fix Your Stuff
Right to Repair
Parts & Tools
Help
Step Type:
Drag to rearrange
Remove 3 silver 12mm Philips #2 screws joining the DMD optical section to the front lens. The three screws cannot be seen in one picture, so three pictures are attached.
The top screw is visible as you look down on the unit.
The left hand screw is seen as you look along the left hand underside of the DMD heat sink
The right hand screw is visible as you look along the right hand underside of the DMD heat sink.
