Introduction
They say time makes fools of us all, but that hasn’t stopped Xiaomi from working around the clock on a totally redesigned Mi Watch. Does their newest timepiece earn its place on your wrist? Tick tock, only this teardown can tell.
To keep up with all timely teardown developments, follow us on Twitter, Instagram, and Facebook. For iFixit delivered, check out our newsletter.
We don't want to say we're killing time, but maybe you should look over these tech specs while we get the teardown table warmed up:
1.39 inch (35 mm) circular AMOLED display with 454 x 454 resolution
11.8 mm thickness at 32g
Wireless charging
Accelerometer, gyro, heart rate, barometer, compass, SpO2 (Blood Oxygen Testing)
Water resistant to 5 ATM
Bluetooth 5.0
We gossiped a little about last year's Chinese version of the Mi Watch, with its more-than-passing-resemblance to another watch made by that lifestyle company in Cupertino. With this new version, Xiaomi switched to an all-new, circular design.
Side by side with its predecessor (left) and the Samsung Galaxy Watch (right)—we're not seeing major changes in terms of hardware components, but the new design direction is evident. This watch even grew another button, perhaps to keep up with Samsung.
But putting the 42 mm version of the Huawei Watch GT2 right alongside it, we notice an even stronger resemblance.
Maybe there are only so many ways to shape something that straps to your wrist. Let's look inside.
Tool used on this step:Mako Driver Kit - 64 Precision Bits$39.95
Even though it's water resistant up to 50 meters, this Mi Watch opens easily with a Torx T2 bit from our Mako Driver Kit and a little bit of prying. It's nice to be reminded that "waterproof" does not have to mean "glued together."
Our first look inside is also encouraging, as we spot some standard Phillips screws. It would've been even better if only one screwdriver was needed, but luckily we're well prepared.
A little prying frees the battery easily. It’s great to see this common repair got prioritized, with a simple modular connector—no soldering required.
The battery is a 1.62 Wh (420 mAh at 3.85 V) Li-ion block which charges wirelessly.
In addition to the battery, the bottom part of the watch case bears a cable assembly with a tiny vibration motor, the heart rate and SpO2 sensor array, a barometric sensor, and a MEMS microphone.
Hiding behind the sensor board and peeking through the metal shield is a Texas Instruments AFE44l30 Biosensor Analog Front End module.
Tool used on this step:Magnetic Project Mat$19.95
Just two Phillips screws secure the main board—twist them out, and the board floats free as if by magic in this zero-gravity photo that we totally didn't stage.
After removing the mildly glued-in button cable, we find the following on the top side of the board:
Bosch Sensortec BMI270 3-axis accelerometer/gyroscope
About photo 3: I'm wondering - is there a commonly used name for this type of connectors?
We usually call them press-fit connectors.
The bottom side features these chips:
STMicro STM32L4R9ZI6P microcontroller based on an Arm® Cortex®-M4
Paragon PN26Q01AWSIUG 1 Gbit NAND flash memory
AIROHA AG3335MN multi-GNSS chip featuring a MediaTek MT3333 SoC
Geomagnetic sensor (likely)
AKM Semiconductor AK0991x electronic compass
SGMicro SGM41562 Li-ion battery charger w/power path management
Tool used on this step:Deck of Cards$2.99
It's been a pretty good experience so far, but here's the part we've been avoiding. Smartwatches that open through the back usually come with very difficult screen repairs, and the Mi Watch is no exception.
To free up the display assembly, we had to use a heat gun at about 300 °C (572 °F) and a razor blade, causing the screen some damage.
Last thing to come off are the two side buttons, held in place by tiny metal washers (rings) on the inside of the watch body.
- The opening procedure is simple and glueless.
- Connectors are modular and don't overly overlap.
- The battery is easily accessible for repairs.
- Opening requires a somewhat uncommon T2 Torx driver, but Phillips screws grace the inside.
- Many components are grouped together and can’t be replaced individually.
- Display removal seems impractical and repairs will probably require replacing the watch casing.
Final Thoughts
Repairability Score
(10 is easiest to repair)
11 Comments
what is the case/body of the watch made out of?
Plastic. Step 3, image 2 shows metal inserts for the screws that hold the bottom plate on. They wouldn’t do that in a metal case. The plastic threads would easily strip hence the metal inserts.
arturoc -
Where can I buy a separate screen module?
No aliexpress vende.
Anderson -
Buenas tardes, ¿Sabéis dónde se puede conseguir la carcasa de reloj?
With some tapping hope an open source firmware will appear soon on github, by then i’d like to buy one to flash my strava cheating program on it.
where can i find a replacement frame?
Buenas tardes.
Estoy en Colombia y me gustaría saber quién me puede apoyar con información
para reparar mi reloj, debido a que se le ha partido una patica donde va el
Pulso, y no he logrado encontrar un lugar donde lo reparen o me vendan la pieza
del reloj. Agradezco quien me pueda ayudar con esto.
Adjunto una fotografía del Reloj con el daño mencionado.
Hoezo draadloos opladen? Dat gaat gewoon via 2 contacten! Xiaomi heeft wel haar best gedaan om het zo te laten lijken met het ronde oplaadvoetje maar als je hier bij een teardown niet doorheen kijkt vraag ik me af hoe dat kan…
Ruud de Graaf - Reply
