Introduction
If you Xiaomi battery pack rattles then one of the battery strips may break off from the board. This is a simple fix to re attach.
2 Comments
Umm there’s missing steps - the bottom cover also needs removed? How do you push the battery out? Both sides are screwed in please help or finish t his guide thanks
Hi emanoyhl, this guide is a teardown and it looks like it is still in progress, so it's not totally complete yet. I did a search and found a guide for a similar device but for the LED however it does show a little more of the internals. Check out the Jerking LED fix in 10000mAh Mi Power Bank 2S, it's not exactly the same device but it seems to have similar construction and you might be able to reach the battery the same way? I hope this helps!
