Introduction
Xiaomi Mi Mix 2 is easy to repair. If you got your Mi Mix 2 broken by accident, you can repair it by yourself. This video show you how to disassemble Mi Mix 2 step by step.
Video Instructions
This teardown is not a repair guide. To repair your Xiaomi Mi Mix 2, use our service manual.
Witrigs
71,142 Reputation
377 Guides authored
3 Guide Comments
I wish this guide was step by step.
BootlegScarce - Reply Share
can I replace the battery without first removing the motherboard?
Danny Di clemente - Reply Share
I would like to recommend not to disconnect the signal cables unless it is absolutely necessary . The screen can be replaced whithout disconnecting them. I learned it the hard way ,once two connector broke ,one on the mainboard and another on the cable, I had to remove them and solder the cable directly to the mainboard
Albert Teix - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 55
All Time: 12,104
