Xbox 360 S Panel removal
  1. Xbox 360 S Panel removal, Hard Drive: step 1, image 1 of 3 Xbox 360 S Panel removal, Hard Drive: step 1, image 2 of 3 Xbox 360 S Panel removal, Hard Drive: step 1, image 3 of 3
    • Flip the Xbox over and you will see three separate prongs. Pull those back and pull up, then you will see the hard drive. Pull the rectangle fabric piece up.
    • The hard drive should be removed.
  2. Xbox 360 S Panel removal, Bottom Panel: step 2, image 1 of 3 Xbox 360 S Panel removal, Bottom Panel: step 2, image 2 of 3 Xbox 360 S Panel removal, Bottom Panel: step 2, image 3 of 3
    • Move the Xbox with the hard drive facing toward the right.
    • Then insert your Metal Spudger in between the silver ring and the vent. You should here a pop noise which is the clip popping out.
    • Rotate the tool away from the Xbox prying open the bottom plate. Continue that step for all the remaining clips.
  3. Xbox 360 S Panel removal, Top Panel: step 3, image 1 of 3 Xbox 360 S Panel removal, Top Panel: step 3, image 2 of 3 Xbox 360 S Panel removal, Top Panel: step 3, image 3 of 3
    • The top panel is very similar to the bottom panel removal. There will be thirteen clips you need to undo.
    • Make sure the front of the Xbox is facing towards the left. Then use the tool undo the clips just like you did on the bottom panel.
    • DO NOT BREAK ANY OF THE CLIPS.
Finish Line
2 other people completed this guide.
Jack Sweet
190 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 2,370
