This teardown is not a repair guide. To repair your XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver, use our service manual.
    1. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Identify the correct device: step 1, image 1 of 1
      • Make sure you have the correct module in front of you.
      Ask FixBot
    2. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Unlever the metal tabs: step 2, image 1 of 3 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Unlever the metal tabs: step 2, image 2 of 3 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Unlever the metal tabs: step 2, image 3 of 3
      • Flip the SFP+ Module upside down.
      • Find the 2 clicked in metal tabs on each side and use a small flathead to lever them up and out of the casing.
      Ask FixBot
    3. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Removing the jacket: step 3, image 1 of 3 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Removing the jacket: step 3, image 2 of 3 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Removing the jacket: step 3, image 3 of 3
      • Gently, without bending, pull the SFP+ module up and away from the jacket so it comes off.
      • Make sure to store it somewhere safe.
      Ask FixBot
    4. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Top Casing Removal: step 4, image 1 of 3 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Top Casing Removal: step 4, image 2 of 3 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Top Casing Removal: step 4, image 3 of 3
      • Using a PH00 screwdriver, unscrew both the screws holding the top casing to the bottom casing.
      • Make sure to store these somewhere safe.
      Ask FixBot
    5. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Prying the casing: step 5, image 1 of 2 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Prying the casing: step 5, image 2 of 2
      • Flip the SFP+ module sideways.
      • Gently, using a flathead screwdriver, lever the top casing away from the bottom casing, making sure to not fully remove it.
      Ask FixBot
    6. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Removing the top casing: step 6, image 1 of 3 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Removing the top casing: step 6, image 2 of 3 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Removing the top casing: step 6, image 3 of 3
      • Carefully flip the SFP+ module back upright.
      • Remove the top casing gently without making the lever mechanism move.
      Ask FixBot
    7. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, TOSA/ROSA retainer removal: step 7, image 1 of 2 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, TOSA/ROSA retainer removal: step 7, image 2 of 2
      • Using a small flathead screwdriver, lever the TOSA/ROSA retainer away from the bottom casing.
      • Take care to store this somewhere safe.
      Ask FixBot
    8. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Lever removal: step 8, image 1 of 2 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Lever removal: step 8, image 2 of 2
      • Gently, pull the retainer lever away from the rest of the mechanism, making sure to not disturb the spring lock.
      • Store this somewhere safe.
      Ask FixBot
    9. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Spring lock removal: step 9, image 1 of 3 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Spring lock removal: step 9, image 2 of 3 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Spring lock removal: step 9, image 3 of 3
      • Carefully pull the spring lock away from the bottom casing, making sure that the tiny spring is not lost in the process.
      • Make sure to store both pieces in a safe place.
      Ask FixBot
    10. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, PCB Removal: step 10, image 1 of 2 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, PCB Removal: step 10, image 2 of 2
      • Using a small flathead screwdriver, lever the PCB out of the bottom casing by the edge connector, making sure that the TOSA/ROSA are not stuck in place.
      • Make sure to store the bottom casing somewhere safe.
      Ask FixBot
    11. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Full removed PCB: step 11, image 1 of 2 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Full removed PCB: step 11, image 2 of 2
      • Congratulations! You got the PCB out without losing any parts.
      Ask FixBot
    12. XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Chip Identification: step 12, image 1 of 2 XZSNET XZS-SFP10G-LR 10GBASE-LR SFPplus Transceiver Teardown, Chip Identification: step 12, image 2 of 2
      • ROSA.
      • TOSA.
      • EOC5006-S Integrated 10G SFP+ Transceiver and Control IC.
      • 24C16A EEPROM.
      • ??02A Unknown chip most likely laser bias, APC or temperature compensation.
      Ask FixBot
Daniel Rezaie
435 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 121
All Time: 380
