Shop the Holiday Gift Guide
Introduction
Go to step 1 ↓
This Teardown documents the opening of a TomTom START 52 and shows the display assembly, motherboard, speaker, and shielding plate.
The microSD card slot is located under the mount, according to the TomTom user manual. This Teardown therefore begins at the back of the device.
Tools
This teardown is not a repair guide. To repair your TomTom GPS, use our service manual.
    1. TomTom START 52 Teardown, Remove the mount: step 1, image 1 of 3 TomTom START 52 Teardown, Remove the mount: step 1, image 2 of 3 TomTom START 52 Teardown, Remove the mount: step 1, image 3 of 3
      • Power off the navigation device and disconnect all cables.
      • Remove the mount from the back of the device.
      • Remove the visible case screws and set them aside on a magnetic project mat or in separate areas.
      Ask FixBot
    2. TomTom START 52 Teardown, Opening the housing: step 2, image 1 of 3 TomTom START 52 Teardown, Opening the housing: step 2, image 2 of 3 TomTom START 52 Teardown, Opening the housing: step 2, image 3 of 3
      • Insert an iFixit opening pick between the front panel and the rear housing.
      • Release the housing clips around the frame.
      • Carefully flip the display unit to the side.
      • Do not fully remove the display unit as long as the ribbon cable is still connected.
      Ask FixBot
    3. TomTom START 52 Teardown, Remove the shield plate: step 3, image 1 of 3 TomTom START 52 Teardown, Remove the shield plate: step 3, image 2 of 3 TomTom START 52 Teardown, Remove the shield plate: step 3, image 3 of 3
      • Lift the shield plate off the motherboard.
      • Lay the shield plate and screws on a magnetic project mat or in separate areas so that nothing gets mixed up during reassembly.
      • The motherboard, speaker, and display connector are now visible.
      Ask FixBot
    4. TomTom START 52 Teardown, Exposing the motherboard: step 4, image 1 of 3 TomTom START 52 Teardown, Exposing the motherboard: step 4, image 2 of 3 TomTom START 52 Teardown, Exposing the motherboard: step 4, image 3 of 3
      • Check the positions of the screws, ribbon cables, and connectors before disconnecting any further parts.
      • Several shielded areas and ICs are visible on the motherboard.
      • Document the position of the cables and screws before each further removal.
      • This Teardown ends with the motherboard exposed.
      • When reassembling the device, carefully align the display cable, case clips, and brackets, and only tighten the screws until they are finger-tight.
      • Did the repair not go as planned? You can find further help in the TomTom GPS troubleshooting guide.
      Ask FixBot
Author
with
Smax
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 65
All Time: 299
