Introduction
Follow this guide to open your Thomson DK 700 T cassette deck and identify its main components.
Warning, for your safety, unplug the device before performing any work.
Using a Phillips PH2 screwdriver, remove the 4 screws located on the sides of the cover.
With the 4 screws removed, slide the cover toward the back by about 1 to 2 cm, then lift it up.
The device is open.
The power switch (220V).
The power transformer.
The power fuses (2 glass 1.6 A 5 x 20 mm fuses).
Analog VU meter block.
Cassette player/recorder block.
Auxiliary input/output board and sockets.
