This teardown is not a repair guide. To repair your TUFA21 TECHUP Radio, use our service manual.
  1. TUFA21 TECHUP Radio Teardown, TUFA21 TECHUP Radio Teardown: step 1, image 1 of 2 TUFA21 TECHUP Radio Teardown, TUFA21 TECHUP Radio Teardown: step 1, image 2 of 2
    • Flip over the device
    • Remove the batteries.
  2. TUFA21 TECHUP Radio Teardown: step 2, image 1 of 3 TUFA21 TECHUP Radio Teardown: step 2, image 2 of 3 TUFA21 TECHUP Radio Teardown: step 2, image 3 of 3
    Tool used on this step:
    Phillips #00 Screwdriver
    $5.49
    Buy
  3. TUFA21 TECHUP Radio Teardown: step 3, image 1 of 3 TUFA21 TECHUP Radio Teardown: step 3, image 2 of 3 TUFA21 TECHUP Radio Teardown: step 3, image 3 of 3
    • Remove the battery springs from the casing by pulling them up.
    • Example of what a battery spring looks like when already removed
  4. TUFA21 TECHUP Radio Teardown: step 4, image 1 of 1
    • Unscrew the main board
  5. TUFA21 TECHUP Radio Teardown: step 5, image 1 of 3 TUFA21 TECHUP Radio Teardown: step 5, image 2 of 3 TUFA21 TECHUP Radio Teardown: step 5, image 3 of 3
    • Lift up the main board and use your other hand to pull the antenna from its socket
    • Main Board
    • Antenna
    • Antenna Socket
  6. TUFA21 TECHUP Radio Teardown: step 6, image 1 of 3 TUFA21 TECHUP Radio Teardown: step 6, image 2 of 3 TUFA21 TECHUP Radio Teardown: step 6, image 3 of 3
    • Pull the red plastic strip from the casing using your free hand.
  7. TUFA21 TECHUP Radio Teardown: step 7, image 1 of 1
    iFixit Opening Tool
    $1.99
    Buy
    • Remove the board glued to the speaker using your opening tool.
    • You will likely want some isopropyl alcohol to help you break through the adhesive more effectively.
Kyeler W
2,737 Reputation
15 Guides authored
Android Alliance Member of Android Alliance
Community
94 Members
755 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 305
