This teardown is not a repair guide. To repair your StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver, use our service manual.
  1. StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Identify the correct Device: step 1, image 1 of 1
    • Verify that the module is a StarTech.com SFP1000ZXST 1000BASE-ZX SFP transceiver before proceeding.
    Ask FixBot
  2. StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Unlever the metal tabs (Right): step 2, image 1 of 2 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Unlever the metal tabs (Right): step 2, image 2 of 2
    • Locate the recessed retaining tabs on each side of the module and carefully lift them using a small flat-blade screwdriver.
    Ask FixBot
  3. StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Unlever the metal tabs (Left): step 3, image 1 of 2 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Unlever the metal tabs (Left): step 3, image 2 of 2
    • Now unfold the metal tab on the left side.
    Ask FixBot
  4. StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Release the metal retaining pin: step 4, image 1 of 2 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Release the metal retaining pin: step 4, image 2 of 2
    • Release the metal retaining pin by pulling the lever of the SFP module so that it clears the casing.
    Ask FixBot
  5. StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Removing the casing: step 5, image 1 of 3 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Removing the casing: step 5, image 2 of 3 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Removing the casing: step 5, image 3 of 3
    • Flip the SFP module back over and carefully slide back the casing.
    Ask FixBot
  6. StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Remove the lever mechanism: step 6, image 1 of 1
    • Carefully flip the SFP module back over making sure that the lever mechanism is not lost.
    • Make sure you keep it somewhere safe.
    Ask FixBot
  7. StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Removing the holding screw: step 7, image 1 of 3 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Removing the holding screw: step 7, image 2 of 3 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Removing the holding screw: step 7, image 3 of 3
    • Using a PH00 bit, unscrew the 4.3mm centre retaining screw.
    • Make sure to keep it safe.
    Ask FixBot
  8. StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Removing the TOSA/ROSA retaining clip: step 8, image 1 of 2 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Removing the TOSA/ROSA retaining clip: step 8, image 2 of 2
    • Using a flathead bit, gently lever the TOSA/ROSA retaining clip.
    • It should come out very easily.
    • Make sure not to lose this small part.
    Ask FixBot
  9. StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Remove the PCB from the casing: step 9, image 1 of 3 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Remove the PCB from the casing: step 9, image 2 of 3 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Remove the PCB from the casing: step 9, image 3 of 3
    • Now we can safely remove the PCB from the casing and take a closer look.
    • Make sure not to lose casing.
    Ask FixBot
  10. StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Chip Indentification: step 10, image 1 of 3 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Chip Indentification: step 10, image 2 of 3 StarTech.com SFP1000ZXST 1000BASE-ZX SFP Transceiver Teardown, Chip Indentification: step 10, image 3 of 3
    • ROSA
    • TOSA
    • MindSpeed M02095G-12 Gigabit Ethernet Laser Driver and Transceiver IC
    • Unknown chip most likely power control, optical power monitor conditioning, signal-detect support, or protection
    • Unknown chip most likely the SFP module controller/DDM IC
    • Unknown chip most likely a temperature compensation transistor
    Ask FixBot
Daniel Rezaie
415 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 97
All Time: 183
