Using a small Phillips screwdriver, remove the screws from the bottom of the plastic case.
Rubber feet in the four corners must be removed first to gain access to the screws underneath. A sticker may also be covering the middle screw on the left.
Pull off the silver plastic cover and gain access to the internal components.
The rollers, motor, circuit board, and LEDs are all visible now.
First unplug all three wire headers connected to the circuit board.
Unscrew the two screws holding down the circuit board by its corners and remove the board from the laminator.
Hold the roller enclosure from both sides, indicated by the markers, and pull upwards and slightly out.
Free access to the motor and rollers is now possible.
Remove the motor from the rollers by unscrewing the three screws holding them together.
Remove the sensor from the roller enclosure by unscrewing the two spring-loaded screws.
Pull the black washers sideways off the metal rod of the roller.
Pull the gears off.
With the gears off, the plastic panel falls off and the rollers come out of the enclosure.
The laminator is now disassembled.
16 Comments
Why is the screw on the left side so hard to get out?
Thank you! Just needed to open and remove a jam. Followed your guide and all is well.
KQuinn
Thank you for posting these instructions. I was able to remove a quarter that got trapped inside.
