This teardown is in progress – Reload periodically to see the latest changes!
Tools Featured in this Teardown
  1. The Samsung SGH A777
    • The Samsung SGH A777
  2. Remove the black cover by sliding up. Remove the SIM card(not shown) and battery. Remove the SIM card(not shown) and battery.
    • Remove the black cover by sliding up.
    • Remove the SIM card(not shown) and battery.
  3. Remove the six Phillips head screws. Keep track of their position. Using a SIM removal tool or other small point, remove the bottom antenna cover. See photo 2. Place the tool in the bottom right corner and pry it off. Using a spudger, carefully remove the antenna cover. Remove the two screws.
    • Remove the six Phillips head screws. Keep track of their position.
    • Using a SIM removal tool or other small point, remove the bottom antenna cover. See photo 2. Place the tool in the bottom right corner and pry it off.
    • Using a spudger, carefully remove the antenna cover. Remove the two screws.
  4. Using a spudger pry the back cover off carefully. Using a spudger pry the back cover off carefully.
    • Using a spudger pry the back cover off carefully.
    • Using your fingers or a spudger remove the two side buttons. Note their positions. These should easily pop off.
  5. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  6. Remove the two screws surrounding the camera. Remove the two screws around the top of the battery spot. Pry the black midplate off the phone.
    • Remove the two screws surrounding the camera.
    • Remove the two screws around the top of the battery spot.
    • Pry the black midplate off the phone.
    • Be careful as the screen is connected still by a ribbon cable.
    • Remove the entire Samsung model number sticker.
    • Slide the metal sliding mechanism up.
    • Remove the two screws.
  7. Carefully flip the motherboard up. Flip it from bottom to top. Disconnect the ribbon cable with a spudger.
    • Carefully flip the motherboard up. Flip it from bottom to top.
    • Disconnect the ribbon cable with a spudger.
  8. Pry starting at the bottom with a spudger. Remove the cover. This will require some force and a guitar pick.
    • Pry starting at the bottom with a spudger. Remove the cover. This will require some force and a guitar pick.
  9. Remove the daughter board and lift the small blue flex cable from the back of the LCD.
    • Remove the daughter board and lift the small blue flex cable from the back of the LCD.
    • Remove just enough of the blue sticker to disconnect the orange flex cable. Flick the brown connector up and remove.
    • Remove the camera assembly.
  10. Using a guitar pick, carefully pry up the LCD shield plate from the sides. Be careful not to crack the LCD. Don't touch the LCD!
    • Using a guitar pick, carefully pry up the LCD shield plate from the sides.
    • Be careful not to crack the LCD. Don't touch the LCD!
    • Use a spudger edge around the edges of the lens. Remove carefully and use 3M to reattach.
  11. Flick the little brown connector up and remove the orange flex cable.
    • Flick the little brown connector up and remove the orange flex cable.
Josh Bacon
151 Reputation
3 Guides authored
One Comment
My cell phone SGH a777 has lost the sound and how to correct an entry does not function.
I want to have it repaired. Where should I bring it to have it repaired?
Vicente Paladin Molar - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,522
