Tools Featured in this Teardown
Video Overview
This teardown is not a repair guide. To repair your Samsung Galaxy Buds Plus, use our service manual.
    Final Thoughts
    • External assemblies are held together with clips instead of glue, making for a non-destructive entry process.
    • Disassembly can be accomplished with common prying tools and a Phillips screwdriver.
    • The earbuds use rechargeable coin-cell batteries that are easier than ever to replace.
    • Opening procedure is a bit unorthodox, and can cause cosmetic damage to the buds.
    • Careful prying is required throughout to separate components without tearing fragile cables or otherwise damaging the buds.
    Repairability Score
    7
    Repairability 7 out of 10
    (10 is easiest to repair)
Taylor Dixon
60,267 Reputation
94 Guides authored
Teardown Team Member of Teardown Team
Community
2 Members
2,035 Guides authored
6 Comments
Would be nice if you could ID the rest of the major IC’s too.
Sean Davis - Reply
where can I find replacement parts?
Michel - Reply
More wireless earbud teardowns, please! I would also like to see the Galaxy Buds+ drivers.
Mike Housholder - Reply
possible to swap in a higher capacity battery for the buds+ and the case to increase total usable time in between charging.
K T - Reply
is there space to possibly double the capacity of buds case by soldering another 1.03wh battery in parallel?
K T - Reply
Past 24 Hours: 4
Past 7 Days: 90
Past 30 Days: 321
All Time: 14,793
