Fix Your Stuff
Right to Repair
Store
Tools Featured in this Teardown
This teardown is not a repair guide. To repair your Samsung GT-E1200I, use our service manual.
  1. I have used the Jimmy for this job. Be careful when you pry with your Jimmy. It can hurt you if you use it the wrong way.
    • I have used the Jimmy for this job.
    • Be careful when you pry with your Jimmy. It can hurt you if you use it the wrong way.
    • All the tools featured in this guide are available in the Pro Tech Toolkit.
  2. Use a Phillips #00 screwdriver to remove the three screws. Pry and remove the panel with an opening pick. Pry and remove the panel with an opening pick.
    • Use a Phillips #00 screwdriver to remove the three screws.
    • Pry and remove the panel with an opening pick.
  3. Remove the speaker with a spudger.
    • Remove the speaker with a spudger.
    • Do not force it off. If you do, you could break your speaker.
  4. Remove the vibracall engine with the tweezers
    • Remove the vibracall engine with the tweezers
  5. Remove the mainboard with the spudger: Move on side here for detach the screen Pull up here for remove the mainboard
    • Remove the mainboard with the spudger:
    • Move on side here for detach the screen
    • Pull up here for remove the mainboard
    • The screen is soldered to the mainboard. If you are replacing your screen, you need a desoldering iron.
  6. Separate the rubber side of the keyboard from the rest of structure
    • Separate the rubber side of the keyboard from the rest of structure
  7. It's all done!
    • It's all done!
Stefano De Rossi
219 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 97
All Time: 149
