This teardown is not a repair guide. To repair your Roborock Q5 Pro, use our service manual.
    1. Roborock Q5 Pro: Teardown, Remove the dustbin.: step 1, image 1 of 3 Roborock Q5 Pro: Teardown, Remove the dustbin.: step 1, image 2 of 3 Roborock Q5 Pro: Teardown, Remove the dustbin.: step 1, image 3 of 3
      • Flip it on its head, then remove the dustbin.
      Ask FixBot
    2. Roborock Q5 Pro: Teardown, Remove the bottom cover.: step 2, image 1 of 2 Roborock Q5 Pro: Teardown, Remove the bottom cover.: step 2, image 2 of 2
      • Remove the side brush using a PH2 screwdriver.
      • Remove the screws using a PH2 screwdriver.
      • Then, pull the bottom cover off.
      Ask FixBot
    3. Roborock Q5 Pro: Teardown, Remove the battery.: step 3, image 1 of 3 Roborock Q5 Pro: Teardown, Remove the battery.: step 3, image 2 of 3 Roborock Q5 Pro: Teardown, Remove the battery.: step 3, image 3 of 3
      • Lift it up on the left.
      • Detach the connector by squeezing the release tab, then pull it out.
      • Do not simply yank the battery out. You will tear the connector off the motherboard.
      Ask FixBot
    4. Roborock Q5 Pro: Teardown, Remove the bumper's lid.: step 4, image 1 of 2 Roborock Q5 Pro: Teardown, Remove the bumper's lid.: step 4, image 2 of 2
      • Remove the marked screws using a PH1 screwdriver.
      • Then simply lift the lid off.
      Ask FixBot
    5. Roborock Q5 Pro: Teardown, Remove the bumper.: step 5, image 1 of 2 Roborock Q5 Pro: Teardown, Remove the bumper.: step 5, image 2 of 2
      • Flip the robot over.
      • Tilt the bumper forwards and move it upwards to remove it.
      Ask FixBot
    6. Roborock Q5 Pro: Teardown, Remove the side brush motor.: step 6, image 1 of 1
      • Flip it back over.
      • Simply lift it out.
      Ask FixBot
    7. Roborock Q5 Pro: Teardown, Remove the chassis screws.: step 7, image 1 of 1
      • Remove the marked screws using a PH2 screwdriver.
      Ask FixBot
    8. Roborock Q5 Pro: Teardown, Latches.: step 8, image 1 of 3 Roborock Q5 Pro: Teardown, Latches.: step 8, image 2 of 3 Roborock Q5 Pro: Teardown, Latches.: step 8, image 3 of 3
      • The chassis will still be held together by a couple latches on the back.
      • Use a prying tool to get these apart before taking it apart.
      Ask FixBot
    9. Roborock Q5 Pro: Teardown, Take it apart!: step 9, image 1 of 2 Roborock Q5 Pro: Teardown, Take it apart!: step 9, image 2 of 2
      • Flip it over and simply pull the chassis halves apart.
      Ask FixBot
    10. Roborock Q5 Pro: Teardown, Screeeeeeews.: step 10, image 1 of 1
      • Here are the screws organised by steps and type.
      • Use this if needed as a reference during reassembly.
      Ask FixBot
DegenFixer
5,750 Reputation
24 Guides authored
3 Guide Comments
For keeping the screws organized, I use a 24 cup tray that originally held 24 small cupcakes from the bakery section of the Grocery store. I took a Sharpie and numbered the bottom of the cups from 1 to 24. When I take something apart, I write a note as to what was done and what cup the screws went into.
Ron Clobes - Reply Share
great procedure!! thank you
Sandro GABRIELE - Reply Share
Kindly help me with a photo of were to install the spring for the main roller
Mehul Vora - Reply Share
Past 24 Hours: 17
Past 7 Days: 107
Past 30 Days: 408
All Time: 8,653
