This teardown is not a repair guide. To repair your Punkt MP02, use our service manual.
    1. Punkt MP02 Teardown, Remove Sim card tray: step 1, image 1 of 2 Punkt MP02 Teardown, Remove Sim card tray: step 1, image 2 of 2
      • Remove Sim tray
      Ask FixBot
    2. Punkt MP02 Teardown: step 2, image 1 of 2 Punkt MP02 Teardown: step 2, image 2 of 2
      • Using a knife start prying at the back in the top right corner. Then use a metal spudger to remove the back piece.
      • The back piece is held in place with a (not so strong) sticker and some hooks (see second picture for a side view of the hooks).
      Ask FixBot
    3. Punkt MP02 Teardown: step 3, image 1 of 1
      • Remove two screws.
      • in my case one of the screws was covered by a small white sticker
      Ask FixBot
    4. Punkt MP02 Teardown: step 4, image 1 of 3 Punkt MP02 Teardown: step 4, image 2 of 3 Punkt MP02 Teardown: step 4, image 3 of 3
      • using a metal spudger I started separating the two halves of the phone shell on the right of the USB port.
      • by carefully inserting and twisting the spudger I could unclip the two halves to separate them
      • be careful not to insert the spudger too deep, you could damage the mainboard or battery
      • as I wasn't careful enough, the frame broke in two places
      Ask FixBot
    5. Punkt MP02 Teardown: step 5, image 1 of 2 Punkt MP02 Teardown: step 5, image 2 of 2
      • now remove the back half
      • I looks like the back contains some antennas and a speaker
      Ask FixBot
    6. Punkt MP02 Teardown: step 6, image 1 of 3 Punkt MP02 Teardown: step 6, image 2 of 3 Punkt MP02 Teardown: step 6, image 3 of 3
      • now remove the spongy piece that sits ontop of the USB port
      • at this stage I noticed a screw falling on my table and the screw to the right of the USB port was missing
      • I also noticed the screw to the left being loose
      Ask FixBot
    7. Punkt MP02 Teardown: step 7, image 1 of 1
      • Now remove eight screws and the power button
      Ask FixBot
    8. Punkt MP02 Teardown: step 8, image 1 of 1
      • I unplugged the two antenna cables
      • unplug the battery connector
      Ask FixBot
    9. Punkt MP02 Teardown: step 9, image 1 of 1
      • now I opened the clips that hold the ribbon cables
      Ask FixBot
    10. Punkt MP02 Teardown: step 10, image 1 of 3 Punkt MP02 Teardown: step 10, image 2 of 3 Punkt MP02 Teardown: step 10, image 3 of 3
      • at this point the device felt loose and I didn't know how to continue - I noticed after beginning to pull on the battery pull tabs that the mainboard separated
      Ask FixBot
    11. Punkt MP02 Teardown: step 11, image 1 of 1
      • by gently moving the mainboard down (direction of USB port) the mainboard could be separated
      • notice the metal hook that prevents the device from being separated without downwards movement
      Ask FixBot
    12. Punkt MP02 Teardown: step 12, image 1 of 1
      • remove the middle screw
      Ask FixBot
    13. Punkt MP02 Teardown: step 13, image 1 of 2 Punkt MP02 Teardown: step 13, image 2 of 2
      • Now I could remove the screen and main board
      Ask FixBot
Florian
353 Reputation
2 Guides authored
4 Guide Comments
Thank you for posting this guide. It'll become more valuable as these devices age--I anticipate having to replace the battery sometime in the next two years.
vvaylon_k - Reply Share
thank you very much! I had water damage and could open and dry/clean the device before there was any irrevocable damage!
Peter van Mil - Reply Share
Didn’t you break the case? Reassembly is the same but backwards?
Simon Lamouret - Reply Share
Thank you for this post. I was able to open mine and fixit: Battery was not charging and after cleaning the internal connector for the battery all was ok and my Punkt is again alive.
vgusv - Reply Share
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 102
All Time: 4,512
