This teardown is not a repair guide. To repair your Philips SPA3210, use our service manual.
  1. Philips SPA3210 Teardown, Free the cable: step 1, image 1 of 3 Philips SPA3210 Teardown, Free the cable: step 1, image 2 of 3 Philips SPA3210 Teardown, Free the cable: step 1, image 3 of 3
    • Pass the satellite speaker's audio cable through the opening in the back so you can proceed more comfortably.
  2. Philips SPA3210 Teardown, Remove satellite speaker's front cover: step 2, image 1 of 3 Philips SPA3210 Teardown, Remove satellite speaker's front cover: step 2, image 2 of 3 Philips SPA3210 Teardown, Remove satellite speaker's front cover: step 2, image 3 of 3
    • Slip more opening picks under the gray plastic shell to separate it from the orange one, starting from the bottom.
    • Slowly, raise the gray shell equivalently on each side.
    • If you lift only the same side, you risk breaking the plastic connections that attach the shell to the rest of the speaker.
    • You can help yourself with the metal spudger to lift the shell if the fixing glue underneath is too hard.
  3. Philips SPA3210 Teardown, Open the satellite speaker: step 3, image 1 of 3 Philips SPA3210 Teardown, Open the satellite speaker: step 3, image 2 of 3 Philips SPA3210 Teardown, Open the satellite speaker: step 3, image 3 of 3
    • Unscrew all four screws from the orange shell.
    • Separate the orange shell from the white case.
    • You won't need tools for that.
    • Be careful not to separate the orange shell completely because the audio drivers are still connected.
    • Remember that you may have to remove excess glue with preciption tweezers, in order to unscrew.
  4. Philips SPA3210 Teardown, Open the main speaker: step 4, image 1 of 1
    • Remove the volume knob by lifting it with your fingers.
    • Repeat the Step 2 and Step 3.
  5. Philips SPA3210 Teardown, Ta-dan!: step 5, image 1 of 3 Philips SPA3210 Teardown, Ta-dan!: step 5, image 2 of 3 Philips SPA3210 Teardown, Ta-dan!: step 5, image 3 of 3
    • You can unscrew each audio driver for replacement.
    • You can unplug the main speaker's circuit for fixing.
    • You can unscrew (the two main screws) and unglue the power supply for replacement.
    • You can unscrew (the two diagonal screws - position may vary) and open the power supply's cover for fixing.
    • Do not open the power supply if you do not know what you are doing.
Emanuele Artusi
464 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 68
All Time: 257
