Introduction
Disassembly to get to the sensor. Some images are courtesy of lifepixels.com
I have dust particles underneath the sensor glass, so sensor swabs didn't help me. I will try to get inside and under the glass. Additionally the EVF is overbright after a drop and maybe can be rearranged in the process.
You can spot dust marks yourself best if you set the camera to the "A" mode at f/22 and take a picture of the sky
15 Comments
Hello,
and what about Flange back adjustment? Did you solve it somehow?
Hi, what exactly do you mean? I managed to wipe the sensor clean, but correct reassembly is difficult. I might have missaligned the magnets holding the sensor and now the camera sometimes seems to focus very slow.
Andi -
SD card is known as “delicate” one. Use MicroSD adapter with 2-3 plies of adhesive tape on “title side” over contacts. Plus two 5mm stripes near MicroSD slot. Insert adapter and use two stripes to secure your adapter to battery compartment walls. Never move adapter until you need to replace it. Then only use MicroSD cards with some adhesive tape stripe to pull the card from your new slot. Once properly contacted, adapter will avoid “insert SD card back” message on screen.
Hello, I will be referring to the last image on the left side. Is it normal or is it the case with your camera that the piece where the sensor is attached is basically moving freely in the frame? I was opening the camera in order to fix it but now I think it might be normal?
Hi, the sensor is supposed to be "floating" on magnets, it's called IBIS, In Body Image Stabilization.
Andi -
Ah perfect...at least I know now ;) Lets see if I manage to put it back together. Thank you Andi :)
Sophia -
Good luck! Try not to use a magnetic screwdriver. I didn't unfortunately, now the autofocus isn't working anymore and I have to use manual :(
Hey Andi, so I managed to put it back together but now the screen doesnt work anymore. The camera turns on but nothing on the screen or through the view finder. Do you know what this could be about?
Sophia -
so the screen is all black, or do the menus still work and only the sensor not working?
The screen is all black. The camera itself is turnung on, so I can hear it working and theres the green light, but besides that there is nothing. You have any idea what to do next? My initial problem was that the screen sometimes went black when I was holding the camera at a certain angle. I know nothing about cameras, as you can probably tell already, just thought Id try ;)
Sophia -
