Disassembling the remote requires removing screws under the batteries.Removing anything inside will require caution and time .
This teardown is not a repair guide. To repair your Nintendo Wii Remote, use our service manual.
To fully take off the back piece you will have to use your flat head screw driver and gently go along the edge and unclip it.
Gently pull out the whole circuit board ( be careful you may break or rip a wire if you pull to hard )
{CAUTION :WATCH OUT FOR SMALL PARTS}
To remove the buttons you will simply have to take off the grey silicon cover.
To remove the small speaker you can simply pull up .
CAUTION : FOR SMALLER BUTTONS LIKE THE VOLUME ONES .
Gently pry the buttons upwards ,removing the buttons from its holding slot.
CAUTION : WATCH OUT FOR SMALL BUTTONS !
IF YOU WANT TO REBUILD IT FOLLOW STEPS 1-7 BACKWORDS.
Embed this guide
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Preview
