Remove 2 screws first
Lift the cover
Disconnect LCD FPC
Then remove 4 screws
Remove LCD assembly
Open connection bay
Remove 2 screws
Remove 1 screw under the DC power cable notch cover
Remove 4 screws and be ware the length difference
Peel the rubber open from right hand side
Remove 1 screw
Now the back case can be removed.
There's no fragile FPC or cables in this step. Just be patient.
Flash xenon tube terminals, positive connected to capacitor, negative controlled by circuit, and a trigger signal.
Use 10kohm, >2W resistor, connect 2 solder joints for more than 5sec. These are flash condenser/capacitor terminals. DO NOT discharge by SHORT them. (Note 2020-10-13)
Flash solenoid and detecter
Microphones and AF assistant LED
Keypad
Switches
NFC
WiFi and Bluetooth, Lens(back)
CMOS sensor
LCD
Hold the IR-cut filter by its edge, to avoid scratches and contamination.
Use plastic tweezers can avoid scratches.
Top Case
AF assistant LED and left Microphone
Switch board. Right microphone, power switch, shutter button, mode dial, main command dial.
Mode dial cap is double sided taped,
Remove switch board.
Someone else already murdered the main dial and video record button...
Focus adjust and focal plane calibration is important to par-focal lenses
12 Comments
Hi Terrance - the return spring on the on/off switch has gone on mine - are you able to see how to get at this on your stripped down one?
freecycle at evendine dot eclipse dot co dot uk in case I don’t notice it coming up here
hmm, haven’t dug that deep yet… The front case disassembly seems very tricky. Also the IR-cut removal.
Terrance -
Sorry to hear that, I arrive here coming for a solution for the return spring on the on/off switch, is not a big problem but a pain and battery drain if you don’t realise :)
Anyway thanks for your teardown really formative.
I tried to remove the top cover to repair the return spring on the ON/OFF, but I was not able to separate it from the body. I have no solution.
I finally got my hands on a wasted 1J5 and go on with the tear down. FYI top cover is sort of easy to remove, but very tricky. post more photos later.
I some simple words, after removing main PCB, remove some screws from left-upper right-upper and inside flash bay,you can wiggle the top clean off.
And, the power switch is berried very deep. you have to fond all sneaky screws. Aaaaaand the mode dial cap is double-side-taped, some thermal energy needed.
Terrance -
