Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Video Overview
This teardown is not a repair guide. To repair your Nexus 5X, use our service manual.
  1. Nexus 5X Teardown, Nexus 5X Teardown: step 1, image 1 of 2 Nexus 5X Teardown, Nexus 5X Teardown: step 1, image 2 of 2
    • Remove SIM card tray.
  2. Nexus 5X Teardown: step 2, image 1 of 3 Nexus 5X Teardown: step 2, image 2 of 3 Nexus 5X Teardown: step 2, image 3 of 3
    • Use guitar picks to loosen clips securing rear cover and remove back cover.
    • A handy notch is also available for back panel removal.
  3. Nexus 5X Teardown: step 3, image 1 of 3 Nexus 5X Teardown: step 3, image 2 of 3 Nexus 5X Teardown: step 3, image 3 of 3
    • Twist off 10 Phillips screws together.
    • Pry up bottom half and upper half of middle frame.
    • Clips securing midframe exists, be careful to pry up it.
  4. Nexus 5X Teardown: step 4, image 1 of 1
    • Here is the whole middle frame.
    • The bottom half includes loudspeaker. The top half comes with fingerprint scanner.
  5. Nexus 5X Teardown: step 5, image 1 of 2 Nexus 5X Teardown: step 5, image 2 of 2
    • A flexible clip is here. Loosen it and get the loudspeaker assembly only.
  6. Nexus 5X Teardown: step 6, image 1 of 3 Nexus 5X Teardown: step 6, image 2 of 3 Nexus 5X Teardown: step 6, image 3 of 3
    • Tear tape firstly.
    • Loosen adhesive at both sides.
  7. Nexus 5X Teardown: step 7, image 1 of 3 Nexus 5X Teardown: step 7, image 2 of 3 Nexus 5X Teardown: step 7, image 3 of 3
    • Release battery connector.
    • Pry up and remove battery ( Adhesive underneath is not strong).
  8. Nexus 5X Teardown: step 8, image 1 of 3 Nexus 5X Teardown: step 8, image 2 of 3 Nexus 5X Teardown: step 8, image 3 of 3
    • Loosen LCD screen connector and rear camera connector.
    • Pry up and remove motherboard assembly.
  9. Nexus 5X Teardown: step 9, image 1 of 2 Nexus 5X Teardown: step 9, image 2 of 2
    • Release front camera connector and remove it.
  10. Nexus 5X Teardown: step 10, image 1 of 1
    • Here come with motherboard only.
  11. Nexus 5X Teardown: step 11, image 1 of 3 Nexus 5X Teardown: step 11, image 2 of 3 Nexus 5X Teardown: step 11, image 3 of 3
    • The adhesive underneath rear camera is strong. Be careful to pry up and remove it.
  12. Nexus 5X Teardown: step 12, image 1 of 2 Nexus 5X Teardown: step 12, image 2 of 2
    • Adhesive underneath vibration motor is a little bit strong. Pry it up carefully.
  13. Nexus 5X Teardown: step 13, image 1 of 3 Nexus 5X Teardown: step 13, image 2 of 3 Nexus 5X Teardown: step 13, image 3 of 3
    Tool used on this step:
    Buy
    • Tear tape securing earpiece.
    • Use tweezers to pry up earpiece.
  14. Nexus 5X Teardown: step 14, image 1 of 2 Nexus 5X Teardown: step 14, image 2 of 2
    • Remove headphone jack.
  15. Nexus 5X Teardown: step 15, image 1 of 3 Nexus 5X Teardown: step 15, image 2 of 3 Nexus 5X Teardown: step 15, image 3 of 3
    • The sticker underneath LCD with digitizer is a little bit strong, so use heat gun to soften it for a few minutes.
    • With the help of suction cup and guitar picks, remove LCD screen carefully.
  16. Nexus 5X Teardown: step 16, image 1 of 1
    • Done.
Witrigs
70,264 Reputation
377 Guides authored
3 Guide Comments
Where is the camera's microphone placed? I replaced my camera module and now I hear noises when shooting video. May it happen because I haven't glue it back? It happens even while the phone is static, but video is fine.
lioraviram42 - Reply
I suggest that you can take it off and put some new adhesive on the backside of rear camera, and then see what happened.
Witrigs -
Um. You have a teardown that is not the iFixit official teardown, but has the same title, and links to your offsite blog/YT channel? Isn't that a bit misleading?
I think you should rename this Guide so as to not create confusion with the iFixit article with the same title. My 2ยข.
David Spalding - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 12,089
