This teardown is not a repair guide. To repair your Netgear Router, use our service manual.
  1. Netgear G54 Wireless Router Teardown, NetGear G54 Wireless Router: step 1, image 1 of 3 Netgear G54 Wireless Router Teardown, NetGear G54 Wireless Router: step 1, image 2 of 3 Netgear G54 Wireless Router Teardown, NetGear G54 Wireless Router: step 1, image 3 of 3
    • Flip the Net Gear wireless Router over remove four rubber tabs .
    • Place them to the side
  2. Netgear G54 Wireless Router Teardown, Removing  the rubber tabs: step 2, image 1 of 1
    • There four screws that need to be removed.
  3. Netgear G54 Wireless Router Teardown, Removing the four bottom screws: step 3, image 1 of 3 Netgear G54 Wireless Router Teardown, Removing the four bottom screws: step 3, image 2 of 3 Netgear G54 Wireless Router Teardown, Removing the four bottom screws: step 3, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the four screws.
    • Place them aside
  4. Netgear G54 Wireless Router Teardown, Removing the case: step 4, image 1 of 3 Netgear G54 Wireless Router Teardown, Removing the case: step 4, image 2 of 3 Netgear G54 Wireless Router Teardown, Removing the case: step 4, image 3 of 3
    • Removing the bottom top facing up .
    • Put it to the side.
  5. Netgear G54 Wireless Router Teardown, Removing  the front clear plastic: step 5, image 1 of 2 Netgear G54 Wireless Router Teardown, Removing  the front clear plastic: step 5, image 2 of 2
    • Use a spudger on the edge of the clear hard plastic around the outer casing.
    • Use a spudger on the edge to push up the plastic casing.
    • Once the clear plastic casing is removed, place it to the side.
  6. Netgear G54 Wireless Router Teardown, Removing the motherboard: step 6, image 1 of 3 Netgear G54 Wireless Router Teardown, Removing the motherboard: step 6, image 2 of 3 Netgear G54 Wireless Router Teardown, Removing the motherboard: step 6, image 3 of 3
    • Remove the motherboard with bottom case. Then you are done.
  7. Netgear G54 Wireless Router Teardown: step 7, image 1 of 1
    • After remove the motherboard . The top cases of the Router.
kempc8
899 Reputation
7 Guides authored
K and K Fixit Member of K and K Fixit
Business
1 Member
11 Guides authored
2 Comments
bad quality images
Andri Basuseto - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 2,858
