Introduction
For this teardown you should have a small phillips screwdriver a flathead screwdriver or some other kind of prying device. A 3mm phillips screwdriver will work for all of the screws in this teardown. Note: This teardown does not include removing any components from the internal PCB.
Undo the bottom battery clip and remove any AA battery within.
Remove the USB receiver if stored
The device should look as pictured.
Using your prying device, pick at the corner of the lower rubber traction pad on the bottom of the device.
Pull this traction pad off to reveal the screw underneath.
Unscrew this middle screw using the small 3mm phillips screwdriver.
Carefully disconnect the top click pads.
Unscrew the two screws on the top front of the device.
Using prying tool undo the back clip piece shown.
Remove two screws in the top back of the mouse.
Pry the top and bottom halves apart.
The mouse should now have two separate parts as shown.
Using prying tool press against the bottom of each side of the click wheel apparatus to cause it to snap out of place.
Remove 2 Screws from either side of the click wheel on the lower tier of the PCB.
Remove the 3 screws from the top tier of the PCB.
Remove the screw holding the small PCB to the plastic backing
Parts of the PCB are listed below and correspond to the colored circles on the pictures
LED tracking apparatus
Battery power receiving mechanism
Left and Right Click Buttons
Click Wheel Button
Scroll wheel sensing apparatus
Programmable Button
12 Comments
Thank you for this guide. It helped me successfully repair my mouse!
nice post!
thumb up for u!
great, thanks for do it!
thanx a lot :)
Please help me. It can not move pointer but can click and scroll .
Plase point for repair
Really great tutorial! I got my mouse fixed in no time! Congratulations for such a very detailed step-by-step!
My mouse’s left click button has become oversensitive. It double clicks while I drag objects. I could not find a replacement button in online stores. Is there a standard name for the button like OMRON D2FC-F-7N ?
I actually swopped the internals of a 4000 with that of the 6000 perfect fit. Tanx again
do you know how to fix the left click button?, mine is not work
Hi, I love this mouse. I have bought my third one, but I feel that the scroll wheel is a little rough when turning. In the past, before finding this manual, I have opened the mouse and had to break the column which holds the screw which is hidden below back traction pad. However, I fear that when I have to put it back on, it will not sit correctly. Is it possible to buy traction pads for this mouse? Or is it easy to put the traction pad back on?
Regards,
KL
Thanks, I was able to deconstruct my friends mouse in the middle of class.
