This teardown is not a repair guide. To repair your Microsoft Basic Mouse v2.0, use our service manual.
  1. Microsoft Basic Mouse v2.0 Teardown, Microsoft Basic Mouse v2.0 Teardown: step 1, image 1 of 3 Microsoft Basic Mouse v2.0 Teardown, Microsoft Basic Mouse v2.0 Teardown: step 1, image 2 of 3 Microsoft Basic Mouse v2.0 Teardown, Microsoft Basic Mouse v2.0 Teardown: step 1, image 3 of 3
    • Peel off the rubber foot that is stuck under the information sticker on the bottom of the mouse carefully.
    • Save the rubber foot for reassembly.
    • Unscrew the Phillips head screw sunk in under this rubber foot
  2. Microsoft Basic Mouse v2.0 Teardown: step 2, image 1 of 2 Microsoft Basic Mouse v2.0 Teardown: step 2, image 2 of 2
    • On the bottom of the mouse, twist the circular cap with the track ball in it in the direction of the arrows (clockwise) until you can't turn it anymore and flip the mouse back over to let the cap and ball fall out.
  3. Microsoft Basic Mouse v2.0 Teardown: step 3, image 1 of 1
    • Take a spudger to the heel of the mouse where you rest you wrist, and insert the spudger.
    • Pull the spudger around the side until it gets caught on the plastic clip inside.
    • Careful not to break the clip, these are fragile and the plastic is old.
  4. Microsoft Basic Mouse v2.0 Teardown: step 4, image 1 of 1
    • Carefully insert another, small spudger into the hole where the trackball and cap came out of and pry the clip up and unlatch the top shell from the bottom shell.
    • Repeat step 3 and 4 on the other side of the mouse.
  5. Microsoft Basic Mouse v2.0 Teardown: step 6, image 1 of 1
    • With the spudgers still inserted on either side of the mouse and the clips undone of the sides, take one more plastic spudger and pry from the top of the mouse where the cable comes out of.
    • The mouse should come apart with some force, but be careful not to snap any of the clips.
Nick Wrbican
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 95
All Time: 95
