This teardown is not a repair guide. To repair your MacBook Pro 15" Retina Display Late 2013, use our service manual.
    1. MacBook Pro 15" Retina Display Late 2013 Teardown, MacBook Pro 15" Retina Display Late 2013 Teardown: step 1, image 1 of 3 MacBook Pro 15" Retina Display Late 2013 Teardown, MacBook Pro 15" Retina Display Late 2013 Teardown: step 1, image 2 of 3 MacBook Pro 15" Retina Display Late 2013 Teardown, MacBook Pro 15" Retina Display Late 2013 Teardown: step 1, image 3 of 3
      • This top-tier machine from Apple packs some impressive specs:
      • 2.0 GHz quad-core Intel Core i7
      • 8 GB of 1600 MHz DDR3L onboard memory
      • 256 GB of PCIe SSD goodness
      • Intel Iris Pro Graphics
      • 720p FaceTime HD camera
      • 802.11ac Wi‑Fi wireless networking
      • Bluetooth 4.0
      Ask FixBot
    2. MacBook Pro 15" Retina Display Late 2013 Teardown: step 2, image 1 of 3 MacBook Pro 15" Retina Display Late 2013 Teardown: step 2, image 2 of 3 MacBook Pro 15" Retina Display Late 2013 Teardown: step 2, image 3 of 3
      • Easy-upgrade #2: Add a new AirPort card that supports 802.11ac Wi-Fi.
      • Apple's go-to provider of 802.11ac support is again at work. The Broadcom BCM4360 on this AirPort card enables operation on the 5 GHz band at speeds up to 1.3 Gbps.
      • A Broadcom BCM20702 Single-Chip Bluetooth 4.0 Processor gets Bluetoothy things done for your convenience.
      • Also in residence are a pair of Skyworks SE5516 dual-band 802.11 a/b/g/n/ac WLAN front-end modules.
      Ask FixBot
    3. MacBook Pro 15" Retina Display Late 2013 Teardown: step 3, image 1 of 3 MacBook Pro 15" Retina Display Late 2013 Teardown: step 3, image 2 of 3 MacBook Pro 15" Retina Display Late 2013 Teardown: step 3, image 3 of 3
      • One of the few differences: The 15" MBP now has a sleekified heat sink with just a single thermal pad, thanks to the more closely integrated GPU—which we attribute to the "Haswellification" process, as we call it.
      • Another effect of Haswelling your MacBook: This model claims to deliver an extra hour of battery life with the same capacity cells. The more efficient processor likely contributes much to that extra hour of looking at pictures of cats on the internet.
      Ask FixBot
    4. MacBook Pro 15" Retina Display Late 2013 Teardown: step 4, image 1 of 2 MacBook Pro 15" Retina Display Late 2013 Teardown: step 4, image 2 of 2
      • The most noteworthy revisions come on the logic board, including the all-new Haswell Core i7 processor, Iris Pro Graphics, and Thunderbolt 2 support:
      • 2.0 GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.2 GHz) with 6 MB shared L3 cache and Iris Pro graphics
      • 128MB eDRAM cache
      • Elpida J4208EFBG 512 MB DDR3 SDRAM (16 chips for 8 GB total)
      • Intel DSL5520 Thunderbolt 2 Controller
      • Intel Platform Controller Hub
      • Cirrus 4208-CRZ Audio Codec, similar to Cirrus CS4207
      Ask FixBot
    5. MacBook Pro 15" Retina Display Late 2013 Teardown: step 5, image 1 of 1
      • Back of the logic board:
      • SK Hynix H5TC4G63AFR 512 MB DDR3 SDRAM
      • Broadcom BCM15700A2
      • Cypress Semiconductor CY8C24794-24LTXI Programmable System-on-Chip
      • Texas Instruments TPS51980
      • The headphone jack is now soldered onto the logic board—break yours (easily doable through normal wear and tear) and you're looking at a thousand dollar repair
      Ask FixBot
    6. MacBook Pro 15" Retina Display Late 2013 Teardown: step 6, image 1 of 2 MacBook Pro 15" Retina Display Late 2013 Teardown: step 6, image 2 of 2
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • The moment of truth is now upon us—is the battery any easier to take out than the previous, horribly glued-in disaster?
      • We're holding our breath as we gently test the waters with a plastic card...
      • ...And half an hour and several skinned knuckles later, we exhale that breath in a great sigh of disappointment. The battery has the same excessive adhesive, and is just as nearly-impossible to safely remove as before.
      • So much for evolution of design.
      Ask FixBot
    7. MacBook Pro 15" Retina Display Late 2013 Teardown: step 7, image 1 of 2 MacBook Pro 15" Retina Display Late 2013 Teardown: step 7, image 2 of 2
      • MacBook Pro with Retina Display 15" Late 2013 Repairability Score: 1 out of 10 (10 is easiest to repair).
      • Proprietary pentalobe screws prevent you from gaining access to anything inside.
      • As in the MacBook Air, the RAM is soldered to the logic board. Max out at 16GB now, or forever hold your peace—you can't upgrade.
      • The proprietary SSD has changed to a PCIe format, but still isn't a standard 2.5" drive. However, it is a separate daughtercard, and we’re hopeful we can offer an upgrade in the near future.
      • The lithium-polymer battery is glued rather than screwed into the case, which increases the chances that it'll break during disassembly. The battery also covers the trackpad cable, which tremendously increases the chance that the user will shear the cable in the battery removal process.
      • The display assembly is completely fused, and there’s no glass protecting it. If anything ever fails inside the display, you will need to replace the entire, extremely expensive assembly.
      Ask FixBot
33 Guide Comments
Wow, that is insane! and scary at the same time. I just got the 16G model and 512HD. wow
John hale - Reply Share
Hi all ! I have a one year old 15" retina MbP. Could it be possible, if the part becomes available somehow, to replace the Wifi card on my mac with an ac one like on the new model ? Or does the form factor change ?
Phil - Reply Share
Would really like to know the same, except, I have a last gen 13" Retina MbP. Thx for answers. (if you already know where to buy these cards, any help would be appreciated!)
Marc Nunkesser - Reply Share
You read my mind, I was wondering the same thing.
Joshua Ray - Reply Share
yeah, it would be really nice to take advantage of the 802.11ac technology!
Gibran Malheiros - Reply Share
Past 24 Hours: 9
Past 7 Days: 39
Past 30 Days: 253
All Time: 551,474
