This teardown is not a repair guide. To repair your Set-Top Box, use our service manual.
  1. M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: step 1, image 1 of 2 M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: step 1, image 2 of 2
    • Remove 4 circle pads to access the 4 screws. Using a Philips head screwdriver, remove all 4.
    Ask FixBot
  2. M8s OTT TV BOX  Teardown, Remove the bottom: step 2, image 1 of 3 M8s OTT TV BOX  Teardown, Remove the bottom: step 2, image 2 of 3 M8s OTT TV BOX  Teardown, Remove the bottom: step 2, image 3 of 3
    • Remove the 4 circular pads, then using a Phillips screwdriver. Remove the 4 screws.
    • Using the metal spudger in the slits parallel to the Seal you will be able to separate the two piece's.
    • The piece should come off easily.
    Ask FixBot
  3. M8s OTT TV BOX  Teardown: step 3, image 1 of 3 M8s OTT TV BOX  Teardown: step 3, image 2 of 3 M8s OTT TV BOX  Teardown: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • With a firm grip at the base of the cable pull up and away from board.
    • Locate the 4 screws, then using the Phillips screwdriver remove them.
    • Before the board can be removed, be sure to use your tweezers to untape the antenna from the housing.
    • The board should come out with ease.
    Ask FixBot
  4. M8s OTT TV BOX  Teardown, Remove the LED board: step 4, image 1 of 1
    • Using your Phillips head screwdriver remove the 2 screws that hold the unit to the housing
    Ask FixBot
  5. M8s OTT TV BOX  Teardown, Remove the steel heat plate: step 5, image 1 of 2 M8s OTT TV BOX  Teardown, Remove the steel heat plate: step 5, image 2 of 2
    • With your Phillips head screwdriver, remove the 3 screws that hold it in place.
    • The device has been effectively disassembled.
    • Next I will guide you through a Detailed inspection of the main circuit board.
    Ask FixBot
Austin Pollard
1,551 Reputation
3 Guides authored
Reno Phone Repair Member of Reno Phone Repair
Business
1 Member
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 60
All Time: 2,986
