This teardown is not a repair guide. To repair your Lost Vape Ursa Nano (1st generation), use our service manual.
  1. Lost Vape Ursa Nano (1st generation) Teardown, Peel off sticker where led is located: step 1, image 1 of 1
    • Okay, so basically you have to peel off this sticker (use hair dryer because otherwise you can damage this sticker).
    • Next you have to unscrew two tiny screws to loosen the base and electronics inside
    • Now we start the hardest part. You need to push the electronics out through the USB port located at the bottom, using thin tweezers or a needle. (BE CAREFUL IF YOU USE AN ITEM THAT IS TOO THICK, YOU MAY BREAK THE CHARGING PORT)
    • Congratulations, you've taken apart your inhaler. Now make any necessary repairs and follow the steps in reverse to put it back together
Olivier Pyszka
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 46
All Time: 823
