Video Overview
This teardown is not a repair guide. To repair your Lenovo Ideatab A1000, use our service manual.
  1. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 1, image 1 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 1, image 2 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling, Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 1, image 3 of 3
    • Unscrew the two Phillips screws under the memory card and the SIM card covers.
    • Use a plastic tool and remove the back cover.
  2. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 2, image 1 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 2, image 2 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 2, image 3 of 3
    • Unscrew the 8x screws and remove the mother board cover.
    • Disconnect the battery connector.
  3. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 3, image 1 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 3, image 2 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 3, image 3 of 3
    • Volume Buttons, Power Button and Vibration motor
    • Audio Jack Connector, Touch Screen Flex Cable connector, LCD Display Flex Cable Connector.
    • Wi-Fi Antenna Connector, Speaker Connector, GPS Antenna Connector.
  4. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 4, image 1 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 4, image 2 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 4, image 3 of 3
    • Remove the lower speaker and the microphone.
    • Unstuck the Power button, Volume buttons and Vibration motor from the middle frame.
    • Unhook the LCD Display and the Touch screen flex cables.
    • 2x Phillips screws securing the main board.
  5. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 5, image 1 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 5, image 2 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 5, image 3 of 3
    • Remove the Logic board.
    • Be careful, the mother board is sticked to the front outer case.
  6. Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 6, image 1 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 6, image 2 of 3 Lenovo Ideatab A1000 Teardown / Take apart / Disassembling: step 6, image 3 of 3
    • CPU - Mediatek, MT8317ATA
    • Memory chip - eMMC(16GB)+LPDDR2(1GB) - KMK3U000VM-B410
    • Power management chip - Mediatek MT6329BA
    • That's all.
ZFix
191,278 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,528 Guides authored
2 Comments
my mini usb track to board is damaged, can i repair it or can i know from where i can buy the PCB board for Lenovo Idea tab a1000
Jidendran S - Reply
Thanks for this guide!
Pooshon Banerjee - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 14,213
