Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
The Leitz Trinocular Head FSA catalogue number 512 738 is a trinocular Jentsch-type microscope head designed for microscopes with a 160mm mechanical tube length and eyepieces having an outer barrel diameter of 23.2mm. It contains a sliding beamsplitter assembly that directs light to the eyepieces and/or the trinocular port. This guide will provide a partial teardown to allow 'safe' access to the internal prism assembly.
This teardown is not a repair guide. To repair your Leitz Trinocular Head FSA (512 738), use our service manual.
Remove the 3 M3x5.5 Phillips 1 screws from the trinocular tube.
When using an iFixit screwdriver set, using a J1 combined with a smaller bit driver allows for easier access, as the screws are located in an internal recess of the trinocular tube.
Take care not to drop the screws, as the prism assembly is exposed underneath and can be damaged easily.
Removing the bottom cover undoes the factory-set optical alignment. However, the little side-to-side adjustments have very little to no perceivable effect on the generated image.
When using an iFixit screwdriver set, using a J1 combined with a smaller bit driver allows for easier access.
Removing the beamsplitter prism assembly undoes the factory-set optical alignment. However, the little side-to-side adjustments have very little to no perceivable effect on the generated image.
The beamsplitter prism assembly has no stable position without having one prism side touching a surface. Placement on a clean Kimwipe or microfibre cloth is recommended.
