Introduction
One of my LIFX Color 1000 smart lightbulbs has had intermittent connectivity problems since it was installed. The rest of the bulbs have worked very well. After having the troublesome bulb replaced by LIFX, I decided to do a teardown to see what was inside.
In the process I discovered the heatsink was not securely attached, leading me to believe that excess heat was causing the problems. Upon re-assembly I've added a thermal adhesive. I'm optimistic that the bulb may have less trouble - time will tell!
The diffuser is held onto the bulb's base by four snap-lock plastic tabs, which also have a dab of silicone adhesive on them to prevent the diffuser from rattling.
The tabs are just to the right of the small Phillips-head screws you can see in the small space between the diffuser and base.
Insert a strong screwdriver or similar prying tool to bend the plastic tabs. You'll need to bend at least two at once, and then insert something to hold open the one side while you work on the other.
Removing the diffuser exposes the LED PCB. The edge of the WiFi board can also be seen with the antenna protruding.
Note the silicone adhesive on the tabs. You probably don't need to replace this with fresh adhesive, but if you do, make sure it's rated for high temperatures.
On the LED PCB, you can see the white and colored LEDs. The PCB is a thermally-conductive aluminum material.
Around the edge of the bulb's case there is a plastic retaining ring attached by four Phillips-head screws. It's not necessary to remove this for further disassembly.
The LED PCB has a pin header that connects down into the WiFi board. A thermal adhesive pad holds the PCB to the metal bulb case. You can gently pry around the edge of the PCB until the adhesive releases, and the connector separates.
On my bulb, the PCB was not fully-seated on the thermal pad, potentially causing heat-related intermittent faults.
If you compare the under-side of the PCB with the bulb's case, you'll see if the thermal pad was adhered properly.
In these photos you can see the pad was only partially attached on one side. The other side of the PCB was lifted several millimeters away from the bulb's base.
The bulb's metal base serves as a heatsink. You can see the air channels running vertically along the sides. This is why these bulbs should only be installed in a vertical orientation to maintain proper airflow.
If you plan to re-assemble the bulb, you should scrape off all the old thermal pad from the PCB and case. Both surfaces should be clean. Replace it with a good thermal adhesive epoxy, following the manufacturer's directions.
Note the two Phillips-head screws in the central portion of the metal case (marked in green circles). We remove these in the next steps.
Notice the back of the WiFi PCB. There is the female pin-header connector for the LED board, and a series of gold pads for a manufacturing test jig.
If you are feeling adventurous, you may be able to find JTAG, serial ports, or other fun hacking opportunities among those pads.
If you remove the two screws, the electrical base unit slides out of the metal heatsink case. The electronics are potted and not easily accessible.
Re-assembly is the reverse of disassembly.
15 Comments
On the last pic, on the wifi board is that a button or a U.fl connector?
Not a U.fl connector, but very similar, with a socket instead of a pin. It's a switched RF test point used during manufacture, like this: http://www.mouser.com/new/murata/muratas... - Basically, you plug in and it disconnects whatever is downstream; in this case, the PCB antenna. So you could certainly use it for your own antenna, but I'm not sure if anyone makes cable connectors per se; it may only be test probes for use in a manufacturing test jig. Can always rip it off and slap on a u.fl instead =)
That switch is on the older model bulb. It's used to reset the configuration if I recall correctly. Turn off, flip switch, turn on, it resets. Something like that!
Aaron, how much space is available in the base? Thinking of using one for a project and I'd need enough room for a NodeMCU.
Thx!
There's really no space in the base for additional stuff. The line-voltage electronics are epoxy potted, and the rest of the thing is all heatsink and vents.
any chance these would run on low voltage? should just be a little switch mode in the base? i want to see if i can hack them into pool lights. not sure how the wifi will go under water :(
Colored lights would be awesome in a pool! You won't get them to run on low voltage, as the power supply section is epoxy-potted. Also, 2.4GHz frequency used for wifi is the same frequency used by your microwave oven to heat water - the signal would certainly not work under water!
Thanks for your great photos. I'd really like to see the main board which is epoxy potted in that thin plastic case. Is there any chance you got any photos of it out of its place ?
Thanks for the photos. I had a non-functional bulb after a bath full of water poured onto it through the ceiling. A quick dismantle, some surgical spirit and a thorough air and it's working again.
Thanks to your guide, I was able to repair 2 of the original kickstarter bulbs just by replacing the thermal compound. If your bulb starts losing wifi signal, most likely the thermal compound is to blame. I went ahead and re-pasted the rest of them and their wifi reliability went to 100%... easy fix (that you'll need to do every 5-10 years due to thermal paste lifetimes. The older bulbs are basically the same, except instead of the WiFi antenna poking through, there is an array of pins you have to align blind during reassembly.
Wow, that's great to hear! I have a few that are flaky, so I may try this. Thanks for sharing =)
Thanks fir this forum and allowing me to ask a question. Is the any storage in the circuit to expose information about who has connected to the bulb. 2 of my bulbs were hacked I believe and would like to find a way to get their information if I could. Thanks again.
Steve.
