Shop the Holiday Gift Guide
Introduction
Go to step 1 ↓
This is a teardown on a nonfunctional Kodak Advantix C400, this particular one has a stuck film release lever
Tools
This teardown is not a repair guide. To repair your Kodak Advantix C400, use our service manual.
    1. Kodak Advantix C400 Teardown, Remove front face screws: step 1, image 1 of 1
      • Removing exterior screws. (All the same size)
      • with the camera facing you, there are:
      • two on the bottom
      • one on the left
      • two on the right
      Ask FixBot
    2. Kodak Advantix C400 Teardown, Removing the front face: step 2, image 1 of 3 Kodak Advantix C400 Teardown, Removing the front face: step 2, image 2 of 3 Kodak Advantix C400 Teardown, Removing the front face: step 2, image 3 of 3
      • Flip open lens cover
      • Open battery door
      • pry off front cover starting at the bottom, there are only two locking tabs at the top to be mindful of.
      Ask FixBot
    3. Kodak Advantix C400 Teardown, Top cover: step 3, image 1 of 3 Kodak Advantix C400 Teardown, Top cover: step 3, image 2 of 3 Kodak Advantix C400 Teardown, Top cover: step 3, image 3 of 3
      • Gently pry top cover forwards towards lens face
      • watch for side tabs holding in the top
      • Be careful for viewfinder cover as the guide-pins are brittle and can snap off if forcing top off
      • Here is where you can remove/ replace the top slider as it clips in on the back
      Ask FixBot
    4. Kodak Advantix C400 Teardown, Removing lens cover/ viewfinder cover: step 4, image 1 of 1
      • Close the cover
      • There are four screws, two on either side of the camera holding on the lens cover, remove them.
      • Two on the front
      • two on the top
      • Unhook the springs putting tension on the cover
      • The left can be unhooked from the cover itself
      • The right remains on the cover and unhooks from the body
      • The wires are not removable unless desoldered, or cut
      Ask FixBot
    5. Kodak Advantix C400 Teardown, Removing the rear cover: step 5, image 1 of 2 Kodak Advantix C400 Teardown, Removing the rear cover: step 5, image 2 of 2
      • Remove top three screws securing the rear cover
      • (with the rear facing you) begin prying it off starting with the left side (side opposite film lever)
      • If you have a stuck film door with film inside you can begin opening it after this step.
      Ask FixBot
    6. Kodak Advantix C400 Teardown, Opening a stuck film door: step 6, image 1 of 2 Kodak Advantix C400 Teardown, Opening a stuck film door: step 6, image 2 of 2
      • There is a small gear holding closed the lever, switch it out the way with a set of tweezers
      • Pull the lever mechanism and the film door will open
      • if necessary you can either rewind the film back into itself using a #4 flathead or by winding the gears up top in the appropriate direction
      Ask FixBot
Author
with
Michael L
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 61
All Time: 189
