This teardown is not a repair guide. To repair your Jolla, use our service manual.
    1. Jolla Phone (2026) Teardown, Jolla Phone (2026) Teardown: step 1, image 1 of 2 Jolla Phone (2026) Teardown, Jolla Phone (2026) Teardown: step 1, image 2 of 2
      • Using a fingernail remove the SIM card tray.
      Ask FixBot
    2. Jolla Phone (2026) Teardown: step 2, image 1 of 1
      • There is a small slot next to the USB port to pull up the cover.
      • The back cover is clipped on tight, bend it a little to release all clips.
      Ask FixBot
    3. Jolla Phone (2026) Teardown: step 3, image 1 of 2 Jolla Phone (2026) Teardown: step 3, image 2 of 2
      • Using a Philips PH0 to Remove the two screws of the battery bracket.
      • These screws are longer that the rest of the screws
      Ask FixBot
    4. Jolla Phone (2026) Teardown: step 4, image 1 of 1
      • Unplug the battery connector using a spatula or fingernail.
      Ask FixBot
    5. Jolla Phone (2026) Teardown: step 5, image 1 of 2 Jolla Phone (2026) Teardown: step 5, image 2 of 2
      • Remove 6 battery screws using PH0 screwdriver and lift out the battery.
      Ask FixBot
    6. Jolla Phone (2026) Teardown: step 6, image 1 of 1
      • Using a spudger or fingernail partially remove this sticker.
      Ask FixBot
    7. Jolla Phone (2026) Teardown: step 7, image 1 of 1
      • Using a PH0 screwdriver remove 10 screws.
      • Using a PH0 screwdriver remove 1 screw. This screw is smaller than the rest.
      Ask FixBot
    8. Jolla Phone (2026) Teardown: step 8, image 1 of 1
      • Remove the mid frame of the phone.
      • Warning. There is a possibility one or both of the cameras stick to the mid frame. Look out for the camera connector.
      • There is a clip on the mid frame, this keeps the top part down and by carefully pulling the mid frame towards the charging port it will release.
      Ask FixBot
    9. Jolla Phone (2026) Teardown: step 9, image 1 of 1
      • Partially remove the sticker next to the switch bracket.
      Ask FixBot
    10. Jolla Phone (2026) Teardown: step 10, image 1 of 1
      • Remove both antenna cables.
      Ask FixBot
    11. Jolla Phone (2026) Teardown: step 11, image 1 of 3 Jolla Phone (2026) Teardown: step 11, image 2 of 3 Jolla Phone (2026) Teardown: step 11, image 3 of 3
      • Unplug all connectors to the main board.
      • Using the grounding tape, remove the front facing camera, it is not glued down.
      • Carefully lift out the main board
      Ask FixBot
    12. Jolla Phone (2026) Teardown: step 12, image 1 of 2 Jolla Phone (2026) Teardown: step 12, image 2 of 2
      • Using a PH0 screwdriver remove one screw.
      • Unplug both connectors.
      • Remove the SUB board by lifting it out.
      Ask FixBot
frengel
205 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 140
Past 30 Days: 789
All Time: 4,083
