This teardown is in progress – Reload periodically to see the latest changes!
  1. HTC Wildfire S Teardown, HTC Wildfire S Teardown: step 1, image 1 of 1
    • turn off your phone
    • remove back cover and battery
  2. HTC Wildfire S Teardown: step 2, image 1 of 1
    • remove 5 torx t5 screws
  3. HTC Wildfire S Teardown: step 3, image 1 of 1
    • remove back cover using a spudger
    • you can use back cover of your phone
  4. HTC Wildfire S Teardown: step 4, image 1 of 1
    • unplug three ribbon cables from motherboard
    • ribbon cables are easy to damage
  5. HTC Wildfire S Teardown: step 5, image 1 of 1
    • remove 2 phillips screws and remove motherboard
  6. HTC Wildfire S Teardown: step 6, image 1 of 1
    • black ribbon cable is glued to screen
    • remove glue between black ribbon cable and screen
  7. HTC Wildfire S Teardown: step 7, image 1 of 1
    • use spudger to remove screen
  8. HTC Wildfire S Teardown: step 8, image 1 of 1
    • to assemble phone follow the instructions in reverse order
sowa705
191 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,188
