Introduction
Want to know how to open your power supply for cleaning? Here’s how!
This teardown is not a repair guide. To repair your HP power supply D13-180N1A 180 w power supply, use our service manual.
  1. Here is our power supply that we will be taking apart today!
    • Here is our power supply that we will be taking apart today!
  2. The screws are located on the the top and bottom. A flathead screwdriver should do the trick!
    • The screws are located on the the top and bottom. A flathead screwdriver should do the trick!
  3. MacBook Battery Fix Kits
    Starting at $69.99
    Buy Now
    Starting at $69.99
    Buy Now
  4. Now let's start unscrewing
    • Now let's start unscrewing
    • The screws may need some force to unscrew. Be careful or you may risk stripping the screw out!
  5. Once you remove the screws, give it a good jiggle and it should come loose, and slide right off just like butter.
    • Once you remove the screws, give it a good jiggle and it should come loose, and slide right off just like butter.
    • Make sure there are no wires catching anywhere before removing the cover!
  6. Now to the good stuff! Comes to no surprise that there's not a lot going on in here, since it's only a 180 watt. Be careful about touching things inside! Some capacitors may remain charged even after power is disconnected!
    • Now to the good stuff! Comes to no surprise that there's not a lot going on in here, since it's only a 180 watt.
    • Be careful about touching things inside! Some capacitors may remain charged even after power is disconnected!
    • Check out the cover over the pcb. This is to help isolate the area where mains voltage is present
Connor
475 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 45
Past 30 Days: 125
All Time: 125
