Introduction
HP's flagship workstation is called super upgradeable, and touts "tool-free serviceability." Join us to see if this machine is too good to be true, or just what the doctor ordered!
Full disclosure: Generally speaking, iFixit will only perform a teardown on a device we've sourced ourselves through normal retail channels. This gives us the most unbiased, fair assessment of a device, without giving manufacturers a chance to pretty things up for our repairability scanners.
So when HP offered to loan us their pride and joy for the teardown altar, we were a bit hesitant. But in the end, we couldn't resist the chance to get inside this monster and see how it compares to Apple's new fancy mini-tower, the Mac Pro. We told HP to come as close as possible to Mac Pro's $3000 starting price, so it's not so much of an Apples to Oranges comparison.
Find our friendship on Facebook, cool contests and sweet photos on Instagram and digestible nuggets of wisdom on Twitter.
The Apple of HP's eye, the Z820 workstation is their biggest and baddest PC on the market, as well as the closest PC equivalent to Apple's new Mac Pro. So what can you get in your Z820?
16 DIMM slots, configurable to half a Terabyte of ECC DDR3 RAM
Up to 5 3.5-inch 7200 rpm SATA drives for a 15 TB max
Three external 5.25" drive bays
A whole slew of graphics cards options, ranging from the entry-level Nvidia Quadro K600 our sample arrived with, to the $4500 Quadro K6000
Support for one or two Intel Xeon E5 processors
3 x USB 3.0 and 5 x USB 2.0 ports, plus optional Thunderbolt 2 via add-in PCIe card
Before we get inside, let's take a minute to address the difference in size between the Z820 and the Mac Pro.
Scale included for scale.
Hulking in at 17.5" x 8" x 20.7" and 55.4 pounds, the Z820 dwarfs our scale and makes photographing it a challenge.
On the lesser hand, the diminutive Mac Pro is 9.9" tall, 6.6" across, and 16.4 pounds by our bathroom scale.
We'll say it before the comments roll in, it looks like our scale isn't completely accurate at low weights, as Apple specs out the Mac Pro at 11 lbs. Not certified by department of weights and measures.
Flip this, pull that, open it right up, the Z820's side panel pops off with the greatest of ease.
Our motherboard's map is conveniently etched on the interior of the side panel, directing us to all of the riches, and the proper loading order for RAM installation.
We love a good treasure map, and HP seems happy to provide them.
The Mac Pro features a similarly easy-to-open case, so we're one for one so far. But for how long?
Welcome to the space station Z820. Here you will find green-labeled access handles for all of your upgrade and maintenance needs:
Power supply unit
CPU fan assembly
Optical drive release lever
Lower case shroud
Hard drive release catches
We understand that designing a complex device involves a lot of compromise and trade-off.
When Apple decided to make the new Mac Pro compact and power-dense, they gave up a lot of the options that HP felt their top-of-line machine needed. Options like extensive, easily-upgraded internal storage (completely tool-free!), dual CPUs, a ridiculous maximum RAM capacity, optical drives, and user-upgradeable graphics cards.
So what was HP's trade-off? A computer that weighs as much as a siberian husky.
Bulk and weight are certainly of interest, but this is iFixit, so let's talk repairability.
Our Mac Pro guides show you everything you need to know to replace the power supply, in 26 easy steps.
But what if you need to replace the power supply in your Z820? Remove scores of screws, some motherboard power connectors, flip some flops? ...oh wait, we're done.
Continuing our tool-less streak, let's see what's behind these huge panels. The lower is a fairly featureless cover that keeps your PCIe cards separate and cozy.
As for door number two's contents, if you follow us on Instagram, you'll have already seen this sweet piece of hardware.
Provided by our Instagram followers, here's a list of things this component isn't:
A printer of some kind
A miniaturized Portal 2 level
Пылесос (vacuum cleaner)
That carbon 3d printer by max idontknowhislastname
As expected, getting the PCIe video card out of the Z820 was akin to stealing treats from an infant.
The card HP dropped in our loaner box isn't much to write home about, but the upgrade potential is pretty great.
Users can install their own PCIe graphics card, or configure their Z820 with one of several different AMD or Nvidia cards.
So to recap, that's an easy to upgrade card with a wealth of compatible options now and in the future. Not looking so great right now, Mac Pro.
A gentle tug on the drive release lever retracts spring-loaded pins from either side of the three drive bays, allowing us to easily free the filler block... full of turtles.*
The same trick releases the DVD+/-RW drive. Ordinary it may be, but useful if you want to re-watch old favorites unavailable on Netflix streaming.
* No turtles were actually provided by Hewlett Packard. iFixit makes no express or implied warranty to the effect that the Hewlett Packard Z820 workstation PC includes turtles, but holds that it would be totally rad.
To get to the RAM, we had to open the case and remove the fan assembly—one more step than the Mac Pro, so we'll kick a point to Apple for being slightly easier in this respect.
Once you do get to the treasure chamber, the Z820 has some mighty impressive upgrade opportunities.
16 DIMM slots are laid out with 4 individual channels over 8 slots per CPU. Fully loaded, you'll be sporting 512 GB of 8-channel ECC DDR3, up to 1866 MHz.
For what it's worth, our unit came loaded with 4 sticks of Micron 4 GB DDR3, for 16 GB total.
But be careful what you buy, even with memory from the same ‘kit’, the installed location and the size of the memory matters. HP has a .pdf showing optimal memory configurations: http://h20331.www2.hp.com/Hpsub/download....
Screws ahoy! We got so far without tools, we almost forgot what they were, but we're finally busting out some bits to continue the disassembly.
The CPU heat sinks are strapped in with combination flathead/T15 Torx screws. Pick your poison: the accessibility of flathead or the reliability of Torx. Neat!
For big devices, we bust out the big tools. Our Macro Bit Set and ratcheting driver handle are the ideal team to pull out these
Patriot missile launchersfinely finned heat sinks.
'Sinks off, CPUs out. What's our
cereal boxPC prize to be? -
A pair of Intel Confidential Xeon E5-2602 quad core processors!
The Intel Confidential stamp indicates that these are engineering sample processors, loaned out to folks (like HP) who'll be designing computers and applications utilizing its new tech before it hits the market.
Sights set on the motherboard, we've got to do a bit of housework to get it extractable.
The hard drive SATA cables are all neatly labeled, and routed out of the way to the opposite side of the case.
A fan assembly between the motherboard and hard drive cage is sporting that friendly user-serviceable green we love to see. A bit of prying and we pull them out, clearing the way to the motherboard.
Tool used on this step:TR10 Torx Security Screwdriver$5.99
What's this? Security screws? We reluctantly followed this red herring, only to discover HP's engineers had an easier solution in mind.
Don't touch that security driver, these screws actually stay in place and the entire motherboard assembly slides forward on locking pegs.
Safe cracked, motherboard extracted. Let's see what we got:
Intel C602 Chipset
Support for one or two Intel Xeon processors
Three integrated SATA RAID controllers, with 2, 4, and 8 channels
Loads of expansion slots, from the newest PCI Express Gen3 x 16 to legacy PCI for maximum compatibility
Dual integrated Intel GbE LAN
After tunneling through the motherboard we realized the second side panel was hiding a secret compartment. A few failed attempts to open the hidden door reminded us that HP had our backs with their repair documentation.
Lo and behold there were some screws we'd missed and a sliding action we hadn't gotten quite right. Surprising no one, it's a lot easier to work on a machine that has a service manual!
Popping the side panel, we find some nicely bundled cables routed along the interior wall to poke into the main compartment. HP is good at this spring cleaning thing.
The front panel is now free to leave, allowing access to the power buttons and some port action.
Teardown instructions should probably include either a link to the HP documentation or a description of where these hidden screws are.
After removing the two torx screws at the bottom the right cover slides down and can be easily lifted up. (I also submitted this as the 2nd point for this step.)
Found it the “Maintenance and Service Guide” [1] for the Z800 Workstation on page 80 “Removing the Right side panel”
Be aware that the manual is for the Z800, not the Z820, but in this case it helped anyway.
On the Z620, first there’s a T15 that holds the right plastic foot. Push the foot towards the back of the case to release the catches. Under the foot, there are two more T15s in a similar place to the Z800. But the right panel on the Z620 doesn’t budge afterwards. Are there more screws on other places? There’s an indentation on the bottom that seems destined for sticking a flathead screwdriver and prying…
HP Z820 Repairability Score: 10 out of 10 (10 is easiest to repair)
The Z820 is insanely modular, even for a PC desktop, and full of user-replaceable and upgradeable parts.
A whole mess of parts can be pulled out without touching a screwdriver: power supply, hard drives, RAM, optical drives, PCI expansion cards, motherboard assembly, and several fans.
The heat sink screws are combination flathead/Torx, which pairs accessibility with quality.
Lots of room for upgrades means lots 'o' service from this machine.
HP created and shares an entire set of repair and replacement manuals with the world, empowering anyone to fix their workstations. Way to go HP!
I'm concerned about the power supply and CPU shroud having what looks like proprietary, if replaceable, parts.
The CPU is not a problem because it can be replaced by any sandy Bridge EP. The 2602 is a pre-release product, but you have the 2603.
As for the PSU, that is where the highest concern is. HP probably uses better qualities in the PSU, but Dell XPS had proprietary PSU that would short out components. Most servers and workstation class computer have proprietary design on the PSU. It is part of the nature since they have to fit a lot of power in less space.
The link mentioned in step 18 doesn't work
18 Comments
Does the HP come with a hand truck? Yes, everything is included in one giant box, whether you need it or not and everything pulls out without any screws but does this really make a good computer? I worked on cheap PCs that didn't use screws and wish they did because after they were moved a couple times, everything came loose. As for the power supply in this monster (either an 850W or 1125W available, that comes out to 7-9.3A), it would almost require a dedicated circuit to operate properly. I'd hate to see how hot this box runs as well. The late 2013 Mac Pro's max power usage is 270W and 921BTU/h. Part of iFixit's charter was supposed to be reduced use of energy isn't it? This monster is anything but power efficient so I'd put an asterisk by your repairability score and mention its high power usage, high cooling requirements, and heavy weight (most businesses have a two-person rule for lifting something this heavy).
Size doesn't matter for a workstation, since it is not a portable unit. People do not care if the workstation is big or not...
HP needs more power, since you can add several HDDs, and its motherboard has two processors Intel Xeon E5, not just one as Mac Pro has. Moreover, HP has several PCIe ports, where you can add several cards, which consume a lot of power: up to 4 video cards need a lot of power.
The 1125 W is the maximum power not used everyday.
Just because it has a 1000 W PSU doesn’t mean it’s drawing 1000 Watts at all times.
Realistically, making a computer modular and upgradable means longer service life and less e-waste.
If I was looking for an engineering thesis I might see if I could quantify the environmental impact of running the PSU at a less efficient level vs. other potential environmental impacts, including costs of shipping and recycling, and longevity of components.
My old PCI-X G5 PowerMac drew about 125w at idle, and about 300 running folding@home on both CPUs, (according to my Kill-a-watt) despite having a PSU rated for well over that.
I've hauled the HP z800 and z820 around at a previous job where I was on OPS/Desktop and the internals don't come loose. The covers and latches holding the parts in are built like a tank.
just because it has a 1125w power supply doesn't mean it's always outputting all of that power but you do bring up a valid point
This is a professional workstation for the CG/Video industry. Upgradeability is very important in that field, which is why in fact many switched from Apple to this exact model.
As for power consumption, first, it is built to be used with 2 high-end CPUs, not one. Secondly, in the New Mac Pro, you need external power sources for anything that is not included anymore (which is a lot).
It saddens me to see that Apple is not in the Pro/upgradeability market anymore.
With same hardware components as Mac Pro, it will use basically the same power, that's just basic physics. The bonus is you can add more hardware using the same efficient power supply system, rather than use separate and probably less efficient power supplies for each Thunderbolt device. Also people don't try and drop their banana skins into it :-)
I hate to say it but this reminds me of a better powermac g5.
I have two of these my company ordered as VM workstation hosts. While certainly powerful enough for the job, I think it's absurd that these things weigh in at nearly 50 LBs each! My computer table can barely handle it. There are plenty of great mini-towers out there with equal or better processors, RAM, expansion bays, etc. and don't weigh 1/3rd of what this boat anchor does! The case itself is absurdly overweight, and despite what some here believe, yes, you do occasionally need to move these things, unplug cables, etc. HP should really consider a case redesign.
Flathead is not a kind of bit, it's a kind of head. This has nothing to do with the tool needed to drive it. I think you should refer to it as 'slotted', a.k.a the correct term.
I may be alone in this regards, but it's a Flathead Screwdriver, a Flathead Drill Bit, and therefore, a Flathead screw.
How the !&&* do you remove the right side panel?
I am trying to do this on z840 and it looks like it's sealed.
Hi, what is the size of the standoffs in this motherboard?
Not sure I agree with 10/10 for a machine that has a proprietary PSU. If it had a standard sized/shaped ATX PSU there would be no doubt that I could actually get a suitable replacement 5 years later.
I agree with Tim above, on the non-standard PSU. In addition the graphics cards that are usable need to have their PCIe power cables coming out the back, not the top, in order to be compatible with the “featurelss” card cover. Not so featurelss if it prevents using COTS consumer cards!!!
HP just pulled the service manual for this model, and I think a lot of other models, and I’m bouncing around google trying to pick up that which they scattered in the wind.
Guess its just the way everyone in the industry is moving. Enthusiasts built their base that let them build their business, but now its more mainstream so things they are a changin.
You are amiss in describing the removal of the right side panel which is not even mentioned in the service manual; here’s how you do it: With the computer laying face down on the removable latch cover side, orient the bottom of the computer so it is facing you. Remove the two torx screws on the bottom of the right side panel. Now, spin the computer around to the top is facing you. Get a wooden block and a rubber mallet and place the edge of the block on the very edge of the top right panel. Hit the block gently on the left top edge then on the right top edge. Keep doing this and the right side cover will begin to slide down towards the bottom of the computer. Now lift off the right panel.
