This teardown is not a repair guide. To repair your HP G61, use our service manual.
  1. HP G61-430SB Teardown, HP G61-430SB Teardown: step 1, image 1 of 1
    • Turn the device over and remove the screws from the battery. Remove the black panels holding the HDD, ram, and wifi.
  2. HP G61-430SB Teardown: step 2, image 1 of 3 HP G61-430SB Teardown: step 2, image 2 of 3 HP G61-430SB Teardown: step 2, image 3 of 3
    • Remove the RAM modules and the HDD as shown in the pictures.
  3. HP G61-430SB Teardown: step 3, image 1 of 2 HP G61-430SB Teardown: step 3, image 2 of 2
    • Locate the screw for the DVD player and remove it. Then remove the DVD player with a thin spudger.
  4. HP G61-430SB Teardown: step 4, image 1 of 2 HP G61-430SB Teardown: step 4, image 2 of 2
    • Remove the screws to remove the keyboard.
  5. HP G61-430SB Teardown: step 5, image 1 of 2 HP G61-430SB Teardown: step 5, image 2 of 2
    • Remove the screws that are circled in the picture. These screws hold the case of the laptop.
  6. HP G61-430SB Teardown: step 6, image 1 of 1
    • Remove the WIFI antenna cables from WIFI card.
    • Then remove the screws of the WIFI card and remove the card.
  7. HP G61-430SB Teardown: step 7, image 1 of 2 HP G61-430SB Teardown: step 7, image 2 of 2
    • Flip the laptop around and gently remove the keyboard with your fingers.
    • Start with the corners of the keyboard.
    • Gently loosen the keyboard with a flat head screwdriver or a thin spudger.
  8. HP G61-430SB Teardown: step 8, image 1 of 2 HP G61-430SB Teardown: step 8, image 2 of 2
    • After removing the keyboard, find the other screws located in the grey panel.
    • Remove the black plastic. Be careful with the white flat cable.
  9. HP G61-430SB Teardown: step 9, image 1 of 1
    • Remove the black flat wire of the LCD screen from the motherboard.
  10. HP G61-430SB Teardown: step 10, image 1 of 1
    • Remove the hinge screws with the screwdriver from the left side to the right side.
    • Under one of the two hinges, there is a hidden screw (case)
  11. HP G61-430SB Teardown: step 11, image 1 of 2 HP G61-430SB Teardown: step 11, image 2 of 2
    • Remove the audio boxes.
    • Remove all the other wires and cables.
    • Then gently separate the screen from the case.
  12. HP G61-430SB Teardown: step 12, image 1 of 2 HP G61-430SB Teardown: step 12, image 2 of 2
    • Use an iOpener to separate the grey case from the bottom case.
    • Careful: the battery compartment is together with the grey panel.
    • Tip: "slide" the iOpener while opening until you hear clicks. It is easy if you slide.
  13. HP G61-430SB Teardown: step 13, image 1 of 3 HP G61-430SB Teardown: step 13, image 2 of 3 HP G61-430SB Teardown: step 13, image 3 of 3
    • Remove the motherboard by removing the screws first. Be careful with the cables and the wires.
    • Be careful with the connector of the DC power jack. You can replace the USB drivers on that side as well.
  14. HP G61-430SB Teardown: step 14, image 1 of 3 HP G61-430SB Teardown: step 14, image 2 of 3 HP G61-430SB Teardown: step 14, image 3 of 3
    • Remove the cooler.
  15. HP G61-430SB Teardown: step 15, image 1 of 1
    • To remove the Processor, unlock the processor socket with a flat screwdriver.
    • Then gently remove the Processor.
Kevin D
7,294 Reputation
21 Guides authored
2 Comments
Thanks a bunch this helped a whole lot!!!!
Teresa halley - Reply
Thank you very much. Very well explained :)
a.thorne.987 - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 18
All Time: 8,905
