This teardown is not a repair guide. To repair your HP Elite Mini 800 G9, use our service manual.
  1. HP Elite Mini 800 G9 Teardown, Open the Chassis: step 1, image 1 of 2 HP Elite Mini 800 G9 Teardown, Open the Chassis: step 1, image 2 of 2
    • First we need to turn the device around.
    • Unscrew the thumbscrew on the back using a Torx 15 bit or a flathead screwdriver
    • Slide the top off as shown
    • The fan can be removed by rotating it up and out as shown
    • Once the fan is out of the way unplug the fan
  2. HP Elite Mini 800 G9 Teardown, RAM Removal: step 4, image 1 of 3 HP Elite Mini 800 G9 Teardown, RAM Removal: step 4, image 2 of 3 HP Elite Mini 800 G9 Teardown, RAM Removal: step 4, image 3 of 3
    • The RAM shrowd can be moved out of the way to give access to the RAM
    • Press down and out on the installed RAM to unclip it then pull it out
  3. HP Elite Mini 800 G9 Teardown, SSD and Wifi Card Removal: step 5, image 1 of 3 HP Elite Mini 800 G9 Teardown, SSD and Wifi Card Removal: step 5, image 2 of 3 HP Elite Mini 800 G9 Teardown, SSD and Wifi Card Removal: step 5, image 3 of 3
    • Remove both marked screws with a Phillips #1
    • Unclip both WIFI antenna
    • From there they can both be removed
    • There is a small amount of adhesive on the SSD cover. It can be peeled off to release the SSD
  4. HP Elite Mini 800 G9 Teardown, CPU and Heatsink: step 6, image 1 of 2 HP Elite Mini 800 G9 Teardown, CPU and Heatsink: step 6, image 2 of 2
    • Remove the three marked screws with a Torx 15 bit
    • Once unscrewed the heatsink can be lifted up and towards you at a diagonal
    • The CPU can now be removed by pressing down on the lever, pulling it away from the CPU, and letting it come up to release the CPU latch.
  5. HP Elite Mini 800 G9 Teardown, Motherboard removal: step 7, image 1 of 3 HP Elite Mini 800 G9 Teardown, Motherboard removal: step 7, image 2 of 3 HP Elite Mini 800 G9 Teardown, Motherboard removal: step 7, image 3 of 3
    • First unplug the front speaker and IR receiver.
    • Then using a Torx 15 remove the marked screws
    • To remove the motherboard I would recommend watching the video
    • When reassembling make sure the wifi antenna don't get stuck under the motherboard since you will need those for reassembly
  6. HP Elite Mini 800 G9 Teardown: step 9, image 1 of 1
    • Congratulations you have successfully disassembled your HP desktop.
Caleb Pierce
1,193 Reputation
8 Guides authored
1 Guide Comment
I don't think that's an IR receiver.
Kev. inc - Reply Share
Past 24 Hours: 17
Past 7 Days: 93
Past 30 Days: 414
All Time: 4,541
