Introduction
A look inside the Google Pixel Buds 2
Features:
Sweat and Water Resistant
Bluetooth® 5.0
Spatial vent for in-ear pressure reduction and spatial awareness
Dual beamforming microphones / Voice detecting accelerometer
Up to 5 hours of listening time and up to 2.5 hours of talk time
Capacitive touch sensors / Dual IR proximity sensors
Back View of the Buds
Spatial Vent
Connectors for Charging the Battery when in the carrier / charging case
IR Detector for detecting when the buds are in the charging case or in the ear
IR Detector for detecting when the bud is in the ear
Grounded Metal Grid sound chamber cover
Closeup view of the Grounded Metal Grid
Since the Google Pixel Buds are made of plastic and are glued together, the only way in was to cut into the Google Pixel Bud. This is a destructive teardown
Once in, we are able to get our first look at the Google Pixel Bud's electronics. The stack up the Google Pixel Bud is as follows:
Touch Sensor
Main Circuit board
Battery
Speaker
Microphones
Charging and in Ear IR Detectors (not shown)
View of the electronics when removed from the Google Pixel Bud Enclosure
Flex PCB based Touch Sensor
Main PCB. Contains MCU, Bluetooth Radio, Audio Processing, Power Management, and Sensors
Battery
MEMS Microphones
Speaker Coil, Speaker Magnet, and Speak Diaphragm.
Grounded metal grid sound channel cover
IR Detector for in ear detections
Closeup view of the bottom side of the Main PCB
Unknown component. Labelled "ix6". Please leave a comment if you happen to know this component
Programming Interface and test points. Looks to be the standard ARM 20 Pin connector layout.
Bluetooth Antenna. Runs around the outside of the Main PCB - Top and Bottom
Well, it is definitely not the MAX98502 - you just don't need a 2.2W output to the earbud from a battery-operated device ) It might be something headphones-oriented, for example MAX9723
Closeup view of some of the components on the bottom side of the Main PCB
Closeup view of the top side of the Main PCB
Unknown Device - +7048/A5A59AB - May be the Accelerometer and Gyroscope used for voice detection. Please leave a comment if you know this device
Unknown Device - T 9 51 - Could be Flash Memory or RAM. Please leave a comment if you know this device
Unknown Device - SR 009 - Could be Flash Memory or RAM. Please leave a comment if you know this deviceNew line.
Closeup view some the components on the top side of the Main PCB
Unknown Device - +7048/A5A59AB - May be the Accelerometer and Gyroscope for voice detection. Please leave a comment if you know this device
MEMS Microphone
Could not cross reference the Microphone Part Number, but it appears to be a Goertek Part. Please leave a comment if you happen to know this component
I don’t know how much this helps, but I scanned the DataMatrix and it told me “G20093D180NRD10A”
25 Comments
Great teardown, I can see the effort and finesse that it took., Great job.
Bru this is iFixit
I would also like to see teardown of the case.
Yes. Microphone ports, charging connections, etc are mirrored from right or left buds.
Excellent teardown, kudos Google, they admitted hardware is hard, this is an excellent effort, love the fit.. I've used some other flagships like jabras elite active 75t.. but these are great
Awesome teardown! :)
Hi. Is the bluetooth-chip on left or right Bud?
Bluetooth is in both
It is impressive to see Google added two IR sensors for better wear detection. As far as I know only Airpods/Airpods pro has that, Galaxy buds+ also have it but it is done partly through capacitive touch sensing rather than IR sensor. The usage of BES2300 also seems reasonable as it might be the only Bluetooth SOC that has enough performance for Google to implement various features such as translation to the headset.
Are the buds able to be put back together? The charging pads on one of my buds is recessed, so I wanted to open them up and put it back into place.
No, these devices are not designed to be taken apart. It is very easy to damage the units. I had to cut into it to open it. Inside there are flexible PCBs (easy to damage), and soft cone speaker (easy to damage)
Fantastic tear-down. Thanks so much for doing this!
I’ve had a couple pair of these over the last 2 years and nothing quite compares for the feature set.
I know it’s an older tear-down, but I have a specific question I hope you might be able to help with. My left Pixel Bud 2 fell into a pan in the sink with some oily water. Fully submerged.
It still works, but the bass/mid-range is just gone. The left bud now just sounds tinny and thin.
I’ve tried cleaning it with alcohol, q-tips, a micro vacuum. Can’t seem to make an improvement.
Any insight into what one could try in order to restore the performance? What component might have been impacted in the dunk?
I’ve seen this kind of sound behavior before when some of the external screens get gunked up with earwax. Cleaning them has always restored performance in the past. There’s just nothing left on the surface to clean.
Thanks!
Here is a video of how to replace the dead battery of the Pixel buds two and A-series
Thanks for the teardown, may i know how to charge the buds without the case? I lost the charging case and i wonder what are the pogo pins wiring, VBUS, GND etc..
Did you ever figure out which pin is what on those buds? I have a washed/broken charging case and am trying to charge the buds to see if they survived the bath and drying cycle.
Still no clue about the pinout. i lost my case so i cant charge them :/
Would you be willing to do this with Pixel Buds A-series & Pixel Buds Pro? If you need donated earbuds, I would be willing to do so.
