Introduction
The Google Nest Wifi Point is a Wi-Fi range extender that doubles as a smart speaker with Google Assistant.
The Google Nest Wifi Point opens from the bottom
Use the spudger to completely remove the rubber layer. Starting at the power button provides the best leverage.
Remove the adhesive layer to expose the 4x T4 screws
Remove the 4x T4 screws from the bottom plate of the Google Nest Wifi Point
Use the spudger to pry off bottom cover of unit.
The bottom portion of the unit is held in place with 5 x T6H screws. Note the 9 LEDs on the Google Nest Wifi Point
Once removed, the speaker driver can be exposed as well as the first board that contains 2x LED drivers - Texas Instrument LP5018
The speaker is held in place with 4x T8H screws
Disconnect the speaker from the main board
The main board is connected to a heatsink/sub-chassis with 2x T6H screws
Disconnect the 3 antenna wires from the main board
The sub-chassis is held in place with 4x T7H screws
The sub-chassis also houses 3 antennas
The top board contains 3 DMICs as well as a touch sensor - Cypress CY8CMBR3108
Synaptics AS-370 SoC
Micron MT29F4G08ABAFAH4-IT NAND Flash Memory
Nanya Technology NT5CC128M16JR-EK DRAM
Samsung K4B4G1646E-BYMA000 DRAM
Qualcomm QCA9886 WLAN SoC
Nordic Semiconductor N52811 QFAAA0 1922AG Bluetooth SoC
5 Comments
Is there anyone from the previous gen?
Is it possible to remove the led driver PCB from the base? Mine is completely stuck.
Do you know where I can find a replacement speaker? The sound of mine is cracked.
Beautiful design Google!
