This teardown is not a repair guide. To repair your Garmin Forerunner 255 Music, use our service manual.
      • Remove bands from the watch., they will be annoying later in the process.
      Ask FixBot
      • Heat the watch using a heat gun. I tried using iOpener, didn't work. Heat the watch along the yellow strip, that's where the watch is glued together.
      Ask FixBot
    1. Garmin Forerunner 255 Music Teardown: step 3, image 1 of 2 Garmin Forerunner 255 Music Teardown: step 3, image 2 of 2
      • Wedge the iFixit Opening Tool between the display part and the rest of the body. The strip around the watch (yellow in my case) is on the screen part of the case, so try to put the tool underneath it. If you can't put the tool between, try pulling on the screen part like in the picture. That worked best for me.
      • Reheat the watch whenever it feels cold.
      Ask FixBot
      • When the screen is relatively loose, use iFixit Opening Pick to remove it completely. Circle around the watch with the tool and it'll come loose. The watch doesn't need to be very hot in this step - the screen doesn't hold very well anymore.
      • Be careful while removing the screen not to damage the flexible cable that connects the screen.
      Ask FixBot
      • Remove the screen cable, and the heart rate sensor.
      • Unscrew 4 screws.
      Ask FixBot
      • I had a malfunctioning button. Actually it tore apart from the PCB. Mine was still working, but in case anyone needs to replace theirs, it's the Panasonic EVPAEBB2A. Other EVPAE models have different pressure force, but should work too. Except for EVPAE_E2A, those have different terminal shapes. You can check the datasheet
      Ask FixBot
halloween
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 106
All Time: 1,400
